Using Frobenius method for y'' + (1/x)y' - cy = -cy0
5 replies · 5K views · last reply
razoribbon
I can't seem to figure this one out:
y'' + (1/x)*y' -c*y = -c*y0
where c is just a constant.
if someone could please go through the steps of the frobenius method, i would really appreciate it!
thanks.
Step 1: Since the constant solution, y= cy0 for all x, is clearly a solution you can solve the homogeneous equation y''+ (1/x)y'- cy= 0 and add cy0.
Step 2: Multiply that equation by x to get xy''+ y'- cxy= 0.
Step 3: Write
[tex]y= \sum_{n=0}^\infty a_nx^{n+c}[/itex]<br /> differentiate term by term to find y' and y'' and substitute into that equation.<br /> <br /> Step 4: Look just at the terms having lowest power of x. That should be a quadratic equation in c times a<sub>0</sub>. Assume that [itex]a_0\ne 0[/itex] so that the coefficient must be 0 and solve that "indicial equation" for two values of c.<br /> <br /> Step 5: Put each of those values of c into your equation in turn to find two independent solutions to the homogeneous equation. Setting each coefficient of x to a power to 0, you will get a recursive equation for a<sub>n</sub>.[/tex]
i thought frobenius method was to look at the asymptotic solutions? halls what explained was simply how find a series solution?
thank you for such a clear response!
these are my steps:
[tex] y = \sum_{n=0}^{\infty} a_{n}x^{n + c}[/tex]
[tex] \frac{dy}{dx} = \sum_{n=0}^\infty (n + c)a_{n}x^{n + c -1}[/tex]
[tex] \frac{d^{2}y}{dx^{2}} = \sum_{n=0}^{\infty} (n + c)(n + c -1)a_{n}x^{n + c - 2}[/tex]
now i substitute them into the original equation multiplied by x:
[tex] \sum_{n=0}^{\infty} (n + c)(n + c -1)a_{n}x^{n + c -1} + (n + c)a_{n}x^{n + c -1} - {\alpha}a_{n}x^{n + c + 1} = 0[/tex]
the first two terms have the same power of x, so the equation can be simplified:
[tex] \sum_{n=0}^{\infty} (n + c)^{2}a_{n}x^{n + c - 1} - {\alpha}a_{n}x^{n + c + 1} = 0[/tex]
does this mean that the only solution is c = 0? have i done the right things so far?
thanks for your help!
