Using lightbulbs to circulate the air in my room
  • Level: High School
  • Thread starter questionboy
    Air
9 replies · 3K views · last reply
questionboy
If I have lightbulbs at varying heights around the room will the heat push blobs of air around the room and circulate it. Even without a fan or anything blowing.
Like the variance in heat and humidity in my room will make the air travel looking for a more comfortable spot?
:rolleyes: I think you have to turn it on first. :wink: o:)​
Probably best to try to create a chimney effect …
put a tube nearly from the floor to the ceiling (maybe with holes at intervals in the sides), and place a weak heat source beneath it. :smile:
(Of course, if it's cooler outside the room, just run the tube diagonally out of the window, and you won't need a heat source …
even a plank of wood would do: cold air will roll down the topside, and warm air will roll up the underside :wink:)
I once tried to do something similar back in high school with a 2 gallon cell model I was making--have water (containing sparkle ribosomes) recirculating throughout the cell using a 100W light bulb shining into the bottom. Didn't really work, which was a shame since I put so much time into it.
In retrospect, the medium was probably too dense and there wouldn't have been a way to create the temperature gradient to get that little water recirculating from the bottom to the top. I probably would've been better off using a propeller or aquarium pump. And in all likelihood, so would you (well, a little ceiling fan, at any rate, unless you're talking a really massive space).
TurtleMeister said:
When I was a kid, I was fascinated by motion lamps.
http://www.tvlamps.net/motion_lamps.html
Ah, nice! Thanks, those are great lamps in that link. I think my aunt had one.
I guess now that most lights are compact fluorescent or LCD, these kinds of motion lamps are gone forever...too bad.
I know someone who used strings of lights wrapped around a spiral staircase to create the same effect. He insists it worked. The results weren't as obvious to visitors. If there was a downward draft, the stairs probably deflected the flow.
what about in my bathroom if i want to dry the room? Keep the lightbulb near the floor.
Should I close the window and doors for greatest effect on drying it?
don't put dangerous electrics in a bathroom!
uhh? :redface: the water has to go somewhere …
how will the room dry if there's no way out? :confused:
and don't put dangerous electrics in a bathroom!
By the way...I hope you realize that while it is true that air will move, the cooling effect you will get will be swamped by the radiant energy of the light bulbs. You are much better off with a fan.
