Using Properties of Logarithms
22 replies · 3K views
FritoTaco
[/B]
Question: Use the properties of logarithms to rewrite and simplify the logarithmic expression.
1. [tex]log_{5}\dfrac{1}{250}[/tex]
Product Property: [tex]log_{a}(uv) = log_{a}u + log_{a}v[/tex]
Quotient Property: [tex]log_{a}\dfrac{u}{v} = log_{a}u - log_{a}v[/tex]
Power Property: [tex]log_{a}u^{k} = k\cdot log_{a}u[/tex]
[tex]log_{5}1 - log_{5}250[/tex]
I know when it's dividing, you split it up by subtracting. (Still not confident in the first step) Do I find out 5 to what power gives it 250? Even if I did that, it won't match 250. Pretty sure I'm missing something I'm unaware of.
Answer: [tex]-3 - log_{5}2[/tex]
FritoTaco said:
[/B]
What is the prime factorization of 250 ?
2, 5
Maybe this: [tex]5^{3} \cdot 2[/tex]
I don't know how to flip it so it's 1/250. That's why I separated them.
Better. And now ##\frac{1}{5^3\,\cdot\,2}## and your rules can be applied.
FritoTaco said:
2, 5
No. Those are the prime factors, but 2⋅5 = 10, not 250.
Do a factor tree.
How many factors of 2 and how many factors of 5 ?
Added in Edit:
I see you have it now.
Not that important. You can use rule two as well. Just know what ##\log_5 1## and ##\log_5 5## is.
Okay thanks guys, so...
[tex]\dfrac{1}{{5^{3}}\cdot2}[/tex]
= [tex]log_{5}5^{3}-log_{5}5^{2}[/tex]
= [tex]3log_{5}5 - 2log_{5}5[/tex]
I'm closer, but still stuck on getting the correct answer, is this good so far?
That's not what the quotient rule says, and what you did right the first time.
Apply them one at a time: quotient rule - product rule - special cases. And don't forget parentheses when in doubt.
Ok, so I see an error. I have a 5 base 5 in the second half of step 2. I think it should be [tex]log_{5}5^{3}-log_{5}2[/tex], then [tex]3log_{5}5^{}-log_{5}2[/tex]. Okay, but how do I get rid of the 5 and have a negative sign in front of the 3?
[tex]\dfrac{1}{{5^{3}}\cdot2}[/tex] [tex]=log_{5}5^{3}-log_{5}5^{2}[/tex]...
Your mistakes are in the quoted step.
You used the quotient rule correctly in the OP, when you obtained
## \log_{5}1 - \log_{5}250 ##​
Now use the factorization of 250: 2⋅53 to deconstruct log5(250).
Notice:
2 is not an exponent. It's a coefficient.​
Okay, so I have this so far: [tex]log_{5}1-log_{5}250[/tex] [tex]log_{5}1-log_{5}(5^{3}\cdot2)[/tex] [tex]log_{5}5^{3}-log_{5}2[/tex] [tex]3log_{5}5-log_{5}2[/tex]
Look at ##\ \log_5(250) = ... \ ## by itself. Then consider that it all comes from the denominator.
Does that mean if it comes from denominator the whole solution becomes negative?
##\frac{1}{{5^{3}}\cdot2}##
The line above should be ##\log_5 \frac{1}{{5^{3}}\cdot2}##
FritoTaco said:
= ##log_{5}5^{3}-log_{5}5^{2}##
No. The thing you're taking the log of is a quotient that also includes a product.
FritoTaco said:
= ##3log_{5}5 - 2log_{5}5##
You're using [tex]tags, which causes the rendered expressions to be centered on their own line. For these equations, [itex](inline LaTeX) would look better, IMO. It's simpler to surround the material with $$ (standalone) or ## (inline) tags.[/itex][/tex]
Okay, guys. This is as far as my knowledge takes me. [itex]log_{5}\dfrac{1}{250}[/itex]
[itex]log_{5}1-log_{5}(5^{3}\cdot2)[/itex]
[itex]log_{5}1-log_{5}5^{3}+log_{5}2[/itex]
[itex]log_{5}1-3log_{5}5+log_{5}2[/itex] (log 5 base 5 cancels out)
[itex]-3+log_{5}2[/itex]
So which step did I go wrong? Also, thanks for the information, I was wondering how to format it.
Above is fine, but why not simplify it instead of dragging along ##\log_5(1)##? Do you know what this equals?
The work below contains an error. The fact that you're dragging along ##\log_5(1)## probably contributed to this error.
Doesn't [itex]log_{5}1[/itex] equal zero? I ignored it when solving the rest of the equation.
Yes, that's the right value.
Here's the work you showed in post#17.
Dragging ##\log_5(1)## along in each of these steps probably caused the error I mentioned.
BTW you are not "solving the equation." You are evaluating an expression; namely ##\log_5(\frac 1 {250})##. Solving an equation and evaluating or simplifying an expression are two completely different concepts.
Here's a better start to this problem:
##= \log_5(1) - \log_5(250)##
## = -\log_5(250)##
## = \dots ##
Yes! It has finally arrived!:
[itex]log_{5}(\dfrac{1}{250})[/itex]
= [itex]log_{5}(1)-log_{5}(250)[/itex]
= [itex]-log_{5}(250)[/itex]
= [itex]-log_{5}(5^{3}\cdot2)[/itex]
= [itex]-log_{5}5^3-log_{5}2[/itex]
= [itex]-3-log_{5}2[/itex]
Thank you for your help people!
Very good !
I think that one thing @fresh_42 was suggesting way back in post #4 or thereabouts was to write 1/(250) as (250)-1 .
Then you start with ##\ \displaystyle \log_5\left(\frac 1 {250} \right) = \log_5 (250^{-1})=(-1) \log_5 (250)= \ \dots##
SammyS said:
Very good !
Oh, so that's another way to start. That makes sense. Time to practice more problems!
