Using the Binomial Theorem to Show 3^k C(n,k) = 3^k 1^n-k C(n,k)
The discussion focuses on using the Binomial Theorem to demonstrate that 3^k C(n,k) equals 3^k 1^(n-k) C(n,k). It emphasizes that C(n,k) represents the binomial coefficients, which are derived from the expansion of (x + y)^n. The key insight is that when substituting x and y with specific values, the coefficients can be evaluated. The equation n sum 3^k C(n,k) = 2^(2n) is also highlighted as a significant result of this approach. Understanding these relationships is crucial for applying the Binomial Theorem effectively.
jenny Downer
how do i use binomial to show that 3^k C(n,k) = 3^k 1^n-k C(n,k)
Did you type that correctly? Right now you have stuff = stuff * 1, which is clearly correct...
i wanted to explain a bit more
It should be
n
sum 3^k C(n,k) = 2^2n
k=0
the hint is 3^k C(n,k) = 3^k 1^n-k C(n,k)
The reason C(n, k) are called "binomial coefficients" is that C(n, k) is the coefficient of xk in (x+ y)n What are the coefficients of xk in (3x+ y)n? What do you get if x= y= 1?
The working out suggests first equating ## \sqrt{i} = x + iy ## and suggests that squaring and equating real and imaginary parts of both sides results in ## \sqrt{i} = \pm (1+i)/ \sqrt{2} ## Squaring both sides results in: $$ i = (x + iy)^2 $$ $$ i = x^2 + 2ixy -y^2 $$ equating real parts gives $$ x^2 - y^2 = 0 $$ $$ (x+y)(x-y) = 0 $$ $$ x = \pm y $$ equating imaginary parts gives: $$ i = 2ixy $$ $$ 2xy = 1 $$ I'm not really sure how to proceed from here.
