What factors affect heat rejection in vacuum pump systems?
  • Thread starter Thread starter russ_watters
    Heat Pump Vacuum
The discussion revolves around the factors affecting heat rejection in vacuum pump systems, particularly comparing water-cooled liquid-ring pumps to air-cooled rotary vane pumps. Participants explore the implications of heat rejection in mechanical rooms and how it varies with operational conditions.
  • One participant questions the vendor's estimate of heat rejection, suggesting it may not account for all variables, particularly with ducted exhaust.
  • Another participant proposes that heat rejection increases as a fraction of power input during the pump-down process, but this relationship may change once the system reaches a certain vacuum level.
  • Concerns are raised about the accuracy of estimating heat rejection based on horsepower, with suggestions to measure actual motor amperage for a more reliable assessment.
  • There is a discussion about the potential for significant heat generation in rotary vane pumps due to factors like running friction, which may not be fully captured in vendor specifications.
  • Participants express uncertainty about how the interplay of pressure difference and input mass affects overall heat rejection, indicating a need for calculations to clarify these relationships.
Participants generally agree on the complexity of estimating heat rejection and the importance of considering multiple factors. However, there is no consensus on the exact relationships or calculations needed to determine heat rejection accurately.
Limitations include the dependency on specific pump characteristics, operational conditions, and the need for empirical measurements to validate theoretical estimates. The discussion highlights the variability in performance based on load and system configuration.
TL;DR
How does vacuum pump heat rejection vary with flow rate/load?
I'm working on a project to replace a couple of vacuum pump skids for a lab campus. The existing pumps are water-cooled, liquid-ring pumps. Since they are water cooled, there is effectively no heat rejection into the mechanical room(s) except through un-insulated exhaust pipes. The new pumps are rotary vane, air-cooled, so they will reject heat to the space. So, how much?
The vendor told me to figure 2,500 BTU/hr/hp, which is just another way of saying "all of it". But I don't think that's true. A couple of issues:
1. The vacuum exhaust is ducted (piped) out of the building. Now, since this volume is small and the piping isn't insulated, I'm comfortable saying it still gets rejected into the room. But it would still be nice to know what fraction goes into the airstream. But there may not be an easy way to find this out.
2. I'm pretty sure the heat rejection (and pump horsepower) varies with load, but I'm not certain of that or exactly how. I'm more familiar with compressors, so I'll use an analogy/comparison, to make sure I understand, and I'm looking for confirmation/correction:
Picture a reciprocating compressor (I assume the same thermodynamics applies to a rotary compressor/pump). It's just a piston in a cylinder. As the piston squeezes the air, the air heats up. A certain fraction of the work is held in the compressed air and the rest is released as heat. The amount of lost heat is significant, but it isn't 100%. In addition, the heat rejection changes with load. Consider the firsts stroke of the compressor to pump-up a surge tank/system. The gauge pressure is zero and the pressure rise/compression is pretty close to zero. The compression stroke has nearly zero force behind it, so the work done is near zero and the heat of compression is near zero. As the system pumps up, the pressure rises, force on the piston rises, and work done with each stroke rises. The work done and heat rejection increases as the system is pumped-up to operating pressure. Maximum work is done on the last stroke, and the system if operating at continuous maximum flow operates at maximum power and maximum heat rejection.
Assuming the above is correct:
[As I type this, I realize this is going in a different direction than I thought...]
The vacuum pump kind of works in reverse, but not exactly. The first stroke also does near zero work. But after that, we have two competing parameters:
1. Pressure difference increases with each stroke.
2. Input mass decreases with each stroke.
From this, I conclude: Peak work (power) for a vacuum pump system occurs somewhere in the middle of pump-down, when there is a significant pressure difference, but still a significant mass flow rate. Heat rejection increases as a fraction of power input as the system is pumped down. But once the system is pumped-down, the work done on the last stroke is effectively zero; There is a large compression ratio, but effectively zero volumetric flow rate. And even at maximum working flow rate, the power is still effectively zero.
Thoughts?
Here's where I think I may have gone wrong: when two parameters are trending in opposite directions, intuition can fail you about what happens when you multiply them together. The product may go up or it may go down. I think I will probably need to do the calculations to find out...unless someone already knows the answer to this.
I agree with all your reasoning above.
Sorry, I can't help in this case, I have experience only with portable vacuum pumps, which don't produce significant amount of heat from the pump itself.
If the old and new pumps have comparable capacities, and if you could visit the old installation, perhaps you could estimate how much heat the liquid cooler could have been moving out of the room.
If the system is still operational, measuring the Amps actually used by the motors could give you another estimate.
The estimate of heat based on HP of the motors should consider that only a fraction of HP listed in the nameplate will be used, and even that amount will vary with time of operation and level of achieved vacuum.
Again, measuring the actual Amps flowing into the mechanical room, if at all possible, is a more conservative way of sizing cooling or ventilation of that room.
If the outdoor/indoor delta temperature and humidity is expected to be big sometimes, it may be a good idea to insulate the exhaust ducts, just to prevent condensation on the naked metal surfaces when flow is minimum or zero.
I agree with your reasoning. I suspect that the Vendor's pump curve will give you motor power (vs Pressure, Flow). That isn't everything that you'd like to have, but it will narrow things down. A 'pump temp' plot might also be helpful. 'Running Friction' can be non-trivial with vane pumps - the 'no work' power/heating may be higher than you expect.
