What is the difference between valence and conduction bands in metals?
  • Thread starter Thread starter UMath1
    Conduction
The discussion clarifies the distinction between valence and conduction bands in metals, emphasizing that electrons in the valence band occupy specific molecular orbitals while those in the conduction band can occupy higher energy levels, typically anti-bonding orbitals. The concept of delocalization is crucial, as it indicates that electrons are not confined to individual atoms but can move freely across the metallic structure. The decrease in conductivity with increasing temperature is attributed to the oscillation of atomic kernels, which increases resistance rather than hindering electron transition to higher energy levels. The use of band theory is cautioned against for metals due to potential oversimplifications.
  • Understanding of molecular orbitals and their role in electron configuration
  • Familiarity with band theory and its application to solid-state physics
  • Knowledge of the concepts of delocalization and conductivity in metals
  • Basic principles of thermal effects on electrical conductivity
  • Research the concept of Wannier functions in band theory
  • Study the effects of temperature on electrical conductivity in metals
  • Explore the differences between metals and semiconductors in terms of band theory
  • Investigate the role of atomic oscillations in electrical resistance
Students of solid-state physics, materials scientists, and anyone interested in the electronic properties of metals and their conductivity behavior.
UMath1
I am not sure I quite understand the distinction between the valence and conduction bands in metals. The simple model we learned in Intro to Chemistry explained that electrons in the metals were delocalized and were shared between all the metal atoms in the metallic crystal.
I am not sure if I correctly understand the band model, so correct me if I say something incorrect. According to the band model, the electrons are confined to specific molecular orbitals in between to atoms when in the valence band. If energy is provided then the electrons can occupy higher energy level molecular orbitals in the conduction band. Usually these are the anti-bonding orbitals.
So my questions are the following:
• Aren't the higher energy level molecular orbitals still between just two atoms? How then can the electrons be shared between all the metal atoms?
• Conductivity is supposed to decrease with increasing temperature. Doesn't this contradict with the idea that adding energy will allow the electrons to escape to higher energy levels?
• What exactly does it mean when we say the electrons are delocalized in the conduction bands? Are they still confined to the atoms of the solid? They cannot just escape into a vacuum correct?
Chemistry news on Phys.org
1) I am not really sure. I will look it up once again.
2) The reason for the decrease in conductivity is not because the electrons do not escape into higher energy orbitals. It is because the kernels themselves start oscillating, increasing the resistance to the motion of the electrons.
3) You are correct here.
My teacher has advised me not to use band theory except to explain the properties of semi-conductors. This was because there are other aspects which one might neglect while making assumptions using the band theory ( like your 2nd question). Just telling you.
Even in simple molecules, the molecular orbitals (to be precise the so called "canonical" MO's) are not between just two atoms but extend over the whole molecule. These are the orbitals we also talk about in band theory. It is sometimes possible to introduce an alternative set of orbitals which are localized on the bonds between two atoms. In band theory, these orbitals are called Wannier functions. Now in band theory the condition for the possibility to introduce Wannier orbitals is precisely that the band is either completely full or empty. So if the band is not full, like in metals, the electrons cannot be localized in bonds but are more free to move between the atoms.
Thanks DrDu...! You are the best...!
  • · Replies 24 ·
