Variations of a parameter in a differential equation
The discussion revolves around deriving a differential equation by substituting a parameter, a_{1}, with a variation, Δa_{1}, and analyzing the resulting equation. The user is uncertain about the validity of their approach and seeks clarification on whether the input, u(t), should remain constant. Participants suggest that a_{1}, b_{0}, and b_{1} are constants and discuss the implications of treating Δa_{1}, Δb_{0}, and Δb_{1} as faults in the parameters. There is also a mention of the need for context from the lecture and a suggestion that the parameters change slowly. Overall, the conversation highlights the complexities involved in parameter variations within differential equations.
themagiciant95
I have this differential equation:
[tex]a_{1}\dot{y}(t)+y(t)=b_{0}u(t)+b_{1}\dot{u}(t)[/tex]
and my prof, during a lesson, said that from this equation it's possible to derive that:
[tex]\Delta y(t)=-\Delta a_{1}\dot{y}(t)[/tex]
(Homework Equations are already stated)
I tried to derive this by myself but I'm stuck. What i did it to substitute a_{1} with a_{1} +\Delta a_{1} in the first equation, getting:
(a_{1}+\Delta a_{1})\dot{y}(t)+y(t)=b_{0}u(t)+b_{1}\dot{u}(t)
and trying to subtract a_{1}\dot{y}(t)+y(t)=b_{0}u(t)+b_{1}\dot{u}(t) to it. But it's not the right way. Can you help me ?
Ps: i think i have to make the assumption the input u(t) remains the same, right?
I must admit, it looks a bit random to me. Are ##a_1, b_0, b_1## constants?
Are you sure it doesn't relate to the homogeneous equation?
Yes, let's suppose that its a real system with the parameters a_{1},b_{0}, b_{1}, output y(t) and input x(t) and \Delta a_{1},\Delta b_{0},\Delta b_{1} are faults the parameters
themagiciant95 said:
Yes, let's suppose that its a real system with the parameters a_{1},b_{0}, b_{1} and \Delta a_{1},\Delta b_{0},\Delta b_{1} are faults on this parameters
In general, I can't say it makes much sense to me. There must be something in the context of the lecture.
My prof also said to conjecture that the parameters change really slowly
