Various locations during a vertical circular motion
11 replies · 2K views · last reply
Boomzxc
For a vertical circular motion, its standard to solve for tension at the 4 common points on the circle (North, South, East, West)
My question is, is it possible to solve for tension at other locations?
Example :https://www.dropbox.com/s/c4q1sprphol2tzb/20151127_020345.jpg?dl=0
Can i resolve vertically and horizontally,
I.e. vertically : Tcosθ =mg,
Horizontally : Tsinθ=[mv^2/r]sinθ
Doesn't seem quite right though..
Can advise/explain on how to approach/solve this questions?
Thanks a million!
Does the object have only centripetal acceleration, or does it also have some tangential acceleration?
You stated that Tcosθ = mg. Wouldn't this imply that the vertical component of total acceleration is zero? Why would that be true?
When you wrote Tsinθ=[mv^2/r]sinθ you have not accounted for tangential acceleration.
I would recommend that you take components along the string.
OHHhh
Vertically, Tcosθ=mg + rα
Where α is angular acceleration, rα is tangential acceleration
Horizontally ,Tsinθ=[mv^2/r]sinθ + rα?
I have learn from my lecture notes at that the east and west positions just horizontally T=[mv^2/r] will do
As for top position its tension = weight - mv^2/r
And for bottom position tension = W + mv^2/r
Is it correct? ??
When do we have to consider tangential acceleration?
rα is the tangential acceleration, but it's direction is not vertical. To make the above equation correct, you would need to take the vertical component of rα.
Here you would need to use the horizontal component of rα.
Is it correct? ??
Yes. You should be able to derive these results.
If you are looking for the tension, you do not need to consider the tangential acceleration if you consider the application of F = ma along the direction of the string.
TSny said:
rα is the tangential acceleration, but it's direction is not vertical. To make the above equation correct, you would need to take the vertical component of rα.Here you would need to use the horizontal component of rα.Yes. You should be able to derive these results.If you are looking for the tension, you do not need to consider the tangential acceleration if you consider the application of F = ma along the direction of the string.
How to apply Newton's 2nd law in the direction of the string?
∑F=ma,
T=mv^2/r?
Please help):
You know that there are two forces acting on the pendulum bob. Can you find the component of each of these forces along the string? Note that this is the same as finding the "centripetal" component of each force. One of the forces happens to act in the centripetal direction, so the centripetal component of that force is the entire force. However, the other force does not act in the centripetal direction. You will need to use a little trig to find the centripetal component of that force.
Only tension is acting in the direction of centripetal force, weight is vertically down?
Right, the weight acts vertically down. But the weight does have a nonzero component along the string. You need to find this component of the weight.
Weightcosθ?
Yes. Now set up the second law along the centripetal direction:
ΣFc = mac
where the "c" subscript refers to components of force or acceleration in the centripetal direction.
ΣFc = mac
ΣF=ma
In the direction of centripetal acceleration,
T-Wcosθ=mv^2/r?
Boomzxc said:
ΣF=ma
T-Wcosθ=mv^2/r?
Yes, that looks good.
