MHB Vector equation of a spherical surface
The discussion revolves around deriving the vector equation of a spherical surface defined by the equation $(\mathbf{x} - \mathbf{b})\cdot\mathbf{x} = 0$. It establishes that this equation represents a sphere centered at $\mathbf{x} = \frac{1}{2}\mathbf{b}$ with a radius of $\frac{1}{2}b$. Participants clarify that the goal is to prove the distance from point $\mathbf{x}$ to the center $\frac{1}{2}\mathbf{b}$ equals the radius, leading to the expression $(\mathbf{x} - \frac{1}{2}\mathbf{b})^2 = (\frac{1}{2}b)^2$. The conversation emphasizes the importance of understanding the relationship between the vectors involved rather than equating them directly. The thread concludes with a focus on the mathematical proof required to validate the spherical surface equation.
Dustinsfl
Let the position vector of an arbitrary point $P(x_1x_2x_3)$ be $\mathbf{x} =x_i\hat{\mathbf{e}}_i$, and let $\mathbf{b} = b_i\hat{\mathbf{e}}_i$ be a constant vector.
Show that $(\mathbf{x} - \mathbf{b})\cdot\mathbf{x} = 0$ is the vector equation of a spherical surface having its center at $\mathbf{x} = \frac{1}{2}\mathbf{b}$ with radius of $\frac{1}{2}b$.
\begin{alignat}{3}
(x_i\hat{\mathbf{e}}_i - b_i\hat{\mathbf{e}}_i)\cdot x_i\hat{\mathbf{e}}_i & = & x_i^2-b_ix_i
\end{alignat}
How am I supposed to obtain that $b_i = x_i$?
Mathematics news on Phys.org
\begin{alignat}{3}
\end{alignat}
You're not. That would mean $\mathbf b = \mathbf x$, but that is not what you need to prove.
You need to find the distance of $\mathbf x$ to $\frac 12 \mathbf b$ and proof that it is $\frac 12 b$.
That is, can you prove:
$(\mathbf x - \frac 12 \mathbf b)^2 \overset{?}{=} (\frac 12 b)^2$​
$(\mathbf{x} -\frac{1}{2}\mathbf{b})^2 = \mathbf{x}\cdot\mathbf{x} - \mathbf{x}\cdot\mathbf{b} + \frac{1}{4}\mathbf{b}\cdot\mathbf{b}$
How do I go from here?
What do you get from $(\mathbf{x} - \mathbf{b})\cdot\mathbf{x} = 0$?
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
