Vector space axiom with max operation on real numbers
3 replies · 2K views
MyoPhilosopher
Testing Linear Algebra Rules on following statement
R1. u + v = v+u
R2. u + (v + z) = (u + v) + z
R3.1 z + v = v
R3.2 u + z = v
For the following statement:
V = R ≥ 1; x ⊕ y = max (x,y), with z = 1
My attempt is as follows:
Should R3 be z ⊕ (x ⊕ y)?
I am confused at to the notation of this rule. Moreover, I am struggling to find examples and answers of such problems in linear algebra online.
Should I always view such questions (with x,y) as x representing "u" and y representing "v"?
Thank you
I'm guessing to some extent about what you are doing.
The first problem is you seem to be using ##z## as an arbitrary real number and as a "zero"?
The other problem is that sometimes you use ##x + y = x \oplus y = max(x, y)## and sometimes you use normal addition. For example, what I believe you are trying to test is whether, for all ##x, y, z##:
##(x \oplus y) \oplus z = x \oplus (y \oplus z)##
Yes you are correct I severely overlooked that one...
Would you mind explaining to me what the 3rd rule attempts to prove mathematically:
Should it be z ⊕ (x ⊕ y) = x ⊕ y
or z ⊕ x = x AND THEN z ⊕ y = y
I assume you want to use ##z## for the additive identity (normally denoted ##0##) and in this case show whether or not the number ##1## has the properties of an additive identity. Let's use ##z## for this, although I've never seen that notation before. In case, let's use ##u, v, w## as our vectors. You need to show that for all ##u## we have:
##u \oplus 1 = u##
##1 \oplus u = u##
