Velocity addition expressed as gamma
13 replies · 4K views
granpa
if object A is moving with gamma=x in one direction and
object B is moving with gamma=y in the opposite direction then
what is the gamma factor for object A as it would be calculated by object B?
I know the velocity addition rule for relativity but I can't find anything on the net about velocity expressed as gamma.
Well, we would have
x = sqrt(1 - (vA / c)^2), so rearranging gives
x^2 = 1 - (vA / c)^2
(vA / c)^2 = 1 - x^2
vA / c = sqrt(1 - x^2)
Likewise for y, we would have
vB / c = sqrt(1 - y^2)
and similarly for how B measures A, we would have
vBA / c = sqrt(1 - z^2)
So applying the relativistic velocity addition formula, we get
vBA / c = (vA / c + vB / c) / (1 + (vA / c) (vB / c))
sqrt(1 - z^2) = [sqrt(1 - x^2) + sqrt(1 - y^2)] / [1 + sqrt(1 - x^2) sqrt(1 - y^2)]
1 - z^2 = [(1 - x^2) + 2 sqrt(1 - x^2) sqrt(1 - y^2) + (1 - y^2)] / [1 + 2 sqrt(1 - x^2) sqrt(1 - y^2) + (1 - x^2) (1 - y^2)]
1 - z^2 = [2 - x^2 - y^2 + 2 sqrt(1 - x^2) sqrt(1 - y^2)] / [2 - x^2 - y^2 + x^2 y^2 + 2 sqrt(1 - x^2) sqrt(1 - y^2)]
1 - z^2 = 1 - x^2 y^2 / [2 - x^2 - y^2 + x^2 y^2 + 2 sqrt(1 - x^2) sqrt(1 - y^2)]
z^2 = x^2 y^2 / [2 - x^2 - y^2 + 2 sqrt(1 - x^2) sqrt(1 - y^2)]
z^2 = x^2 y^2 / [1 + sqrt(1 - x^2) sqrt(1 - y^2)]^2
z = x y / [1 + sqrt(1 - x^2) sqrt(1 - y^2)]
good lord.
well thank you but I think there might be a few errors in there.
http://en.wikipedia.org/wiki/Lorentz_factor
granpa said:
good lord.
well thank you.
No problem. I do try to be detailed. :smile:
Oops, you're right, I used the inverse of gamma, sorry. I so used to thinking of time dilation and length contraction as sqrt(1 - (v/c)^2) rather than the inverse of gamma. Okay, so we would need to use the inverse for x, y, and z from what I had before, giving
1 / z = (1 / x) (1 / y) / [1 + sqrt(1 - 1 / x^2) sqrt(1 - 1 / y^2)]
z = x y [1 + sqrt(x^2 - 1) sqrt(y^2 - 1) / (x y)]
z = x y + sqrt(x^2 - 1) sqrt(y^2 - 1)
so for very big x and y its close to xy?
I had that vague impression from something that i read somewhere but couldn't find it anywhere
That should have been z = x y + sqrt(x^2 - 1) sqrt(y^2 - 1), sorry again, I editted it. For very big x and y, it's close to 2 x y.
granpa said:
Looks like that inverse gamma thing might be getting both of us now, unless that's my fault. :smile: For gamma, you'd have
x = 1 / sqrt(1 - (v / c)^2)
1 / x = sqrt(1 - (v / c)^2)
(1 / x)^2 = 1 - (v / c)^2
(v / c)^2 = 1 - (1 / x)^2
v / c = sqrt(1 - 1 / x^2)
So for Wolfram, you'd want to enter
sqrt(1 - 1/z^2) = (sqrt(1 - 1/x^2) + sqrt(1 - 1/y^2)) / (1 + sqrt(1 - 1/x^2) sqrt(1 - 1/y^2))
http://www.wolframalpha.com/input/?...-+1/y^2))&asynchronous=pod&s=42&incTime=true"
but Wolfram gives the solution for z as the square of what I gave within a square root form.
I get the same result as you got in #6 independently, and I think I have the gammas the right way up, so ...
--> z = x y + sqrt[(x^2 - 1)(y^2 - 1)]
--> z = x y + sqrt[x^2 y^2 - x^2 - y^2 + 1]
--> z = x y + sqrt[x^2 y^2 (1 - 1/x^2 - 1/y^2 + 1/(x^2 y^2))]
which for large x and y approximates to 2xy (as you said).
I entered:
solve z = sqrt(-1/(((sqrt(1 - 1/x^2) + sqrt(1 - 1/y^2)) / (1 + sqrt(1 - 1/x^2) sqrt(1 - 1/y^2)))^2 - 1))​
and got:
z = sqrt(2 x^2 y^2+2 sqrt(((x-1) (x+1))/x^2) x^2 y^2 sqrt(((y-1) (y+1))/y^2)-x^2-y^2+1)​
granpa said:
I entered:
and got:
Right, that's it. That works out to
z = sqrt[2 x^2 y^2 + 2 x y sqrt(x^2 - 1) sqrt(y^2 - 1) - x^2 - y^2 + 1]
If we square what we got earlier, then
z^2 = x^2 y^2 + 2 x y sqrt(x^2 - 1) sqrt(y^2 - 1) + (x^2 - 1) (y^2 - 1)
z^2 = x^2 y^2 + 2 x y sqrt(x^2 - 1) sqrt(y^2 - 1) + x^2 y^2 - x^2 - y^2 + 1
z^2 = 2 x^2 y^2 + 2 x y sqrt(x^2 - 1) sqrt(y^2 - 1) - x^2 - y^2 + 1
and then taking the square root of z, then, we get
z = sqrt[2 x^2 y^2 + 2 x y sqrt(x^-1) sqrt(y^2 - 1) - x^2 - y^2 + 1]
the same as before. Wolfram just won't take it out of square rooted form.
rapidity (theta, the Minkowski-angle) can be your friend...
tweak your intuition for euclidean-trigonometry...
let x=cosh(theta_A)... where v_A=tanh(theta_A)
let y=cosh(-theta_B)
you want...
z=cosh( theta_A - (-theta_B)) ... the gamma-factor for a relative rapidity
=cosh( theta_A + theta_B )
=cosh( theta_A ) cosh( theta_B) + sinh( theta_A ) sinh( theta_B)
= x y + sqrt(x^2-1) sqrt(y^2-1) ... as grav-universe got in (#2 and #6)
where I used cosh^2(theta)-sinh^2(theta)=1
to write sinh^2(theta)=cosh^2(theta)-1
and that cosh(-theta)=cosh(theta).
