What was the speed of the motorcycle before the collision?
  • Thread starter Thread starter Fishingaxe
    Collision Velocity
The discussion centers on calculating the speed of a motorcycle before a collision with a car. The car has a mass of 1200 kg and travels at 70 km/h, while the motorcycle weighs 250 kg. Using the principle of conservation of momentum, participants derive that the motorcycle's speed before the collision is 75 km/h. The calculations involve converting units and applying the momentum formula, leading to the conclusion that accurate unit conversion is crucial for correct results.
  • Understanding of momentum conservation principles
  • Ability to perform unit conversions between km/h and m/s
  • Familiarity with basic algebra for solving equations
  • Knowledge of mass and velocity relationships in physics
  • Study the conservation of momentum in elastic and inelastic collisions
  • Learn how to convert between different units of speed, specifically km/h to m/s
  • Practice solving collision problems with varying masses and speeds
  • Explore real-world applications of momentum in vehicle safety and crash analysis
Students studying physics, educators teaching momentum concepts, and anyone interested in understanding vehicle collision dynamics.
Fishingaxe
A car with a mass of 1200 kg and a speed of 70 km/h collides in a head-on collision with a motorcycle. The vehicles lock together and continue along with the speed of 45 km / h in the cars original direction. The motorcycle weighing 250 kg.
What is the speed of the motorcycle before the collision?
(The masses of both the are included in the weights given)
Okay, I'm having a hard time with this one.
I've tried to do something like this:
m= 1200kg
v= 70km/h = 19.4m/s
1200*19.4 = 23280N = 23.3kN
1200*19.4+250*x (why I tried something like this is because I had seen a similar problem being solved along these lines, but on that problem all the information was given, so I thought I could solve this by simply giving the motorcykle the speed of X. However I do not understand this at all, so I thought I'd come here and ask for help to put me into the right direction. I'd like to understand every answer I write and you guys are always to a great help.
Hi Fishingaxe! :wink:
Fishingaxe said:
… I thought I could solve this by simply giving the motorcykle the speed of X.
Yes, you're right, you can!
If you carry on, you should get an equation which you can solve for X. :smile:
can someone confirm if the answer is 12.88m/s.
I think I am waaaaaaaaaaaay off.
For a similar problem the calculation looked like this: (6,0kg)(5,0m/s)+(2,0kg)(-8m/s)/8=1,75m/s
So I did: (1200kg)(19.4m/s)+(250kg)(x)/19.4(maybe it's /x?) then I got 23280+250x/19.4 which is hard to solve? I must be a retard on some level. This is probably obvious for most of you.. :s Maybe I am doing a wrong equation?
P=mv
ptot=p1+p2
ptot=(m1+m2)*v
p1=23280
p2=250*x
ptot=(1200+250)*12.5
18125 = 23280 - 250x
250x = 5155
x=20.62
Answer: the velocity of the motorcycle is 20.62 m/s.
Is this correct?
Hi Fishingaxe! :smile:
(just got up :zzz:)
I'm not really understanding your equation. :confused:
It should be total-momentum-before = total-momentum-after.​
EDIT: ooh, you just replied again, hold on I'll have a look! :wink:
Fishingaxe said:
ptot=(m1+m2)*v
p1=23280
p2=250*x
Yes, that's the correct method! :smile:
However, the answer is not in the correct units …
the question gave all the speeds in km/hr, so shouldn't the answer should be in km/hr also? :wink:
There was no need to convert!
Okay, so the answer should be written as 74.2km/h? :)
i don't get 74.2 :confused:
Hm, if the v for the motorcycle is 20.62m/s then the v for it in km/h should be 20.62*60*60?
can you do it in km/hr throughout (ie without converting to m/s and back)?
Nope.
p=mv
p1 = 1200*70 = 84000
p2 = 250*x
ptot (1200+250)*45
65250 = 84000-250x
250x = 18750
x=75
So the velocity is 75km/h.
I am a bit confused though. If I got when I measured in m/s, 20.62m/s. Why shouldn't the speed be, 20.62*60(seconds in 1 minute)*60(minutes in one hour). Then the answer becomes 74232m/h = 74.2km/h?
And what is the correct method to convert m/s to km/h?
lep11 said:
Nope.
1 meter / second = 3.6 km/h so what was wrong?
Fishingaxe said:
65250 = 84000-250x
250x = 18750
x=75
yup! :biggrin:
(and can you see how much simpler that is?)
you must have made a mistake somewhere :wink:
3.6 ?
tiny-tim said:
yup! :biggrin:
3.6 ?
Ah, I used too few decimals when I converted 70km/h to m/s. I used 19.4 instead of 19.44444 ;)A
Thanks for your help :D
  • · Replies 29 ·
