Velocity and acceleration of a particle (polar coords)
The discussion focuses on calculating the radial and transverse velocity and acceleration of a particle defined by polar coordinates \( r = e^t \) and \( \theta = t \). The particle's velocity is derived as \( \dot{\underline{r}} = e^t \underline{\hat{r}} + e^t \underline{\hat{\theta}} \) and the acceleration as \( \ddot{\underline{r}} = 2e^t \underline{\hat{\theta}} \), indicating that the acceleration is purely in the transverse direction. The participants express confusion regarding the implications of these results, particularly the constant angle between velocity and radius, and the nature of radial and transverse velocities.
  • Understanding of polar coordinates and their applications in physics.
  • Knowledge of vector calculus, particularly derivatives of vector functions.
  • Familiarity with the concepts of velocity and acceleration in a polar coordinate system.
  • Ability to perform transformations between polar and Cartesian coordinates.
  • Study the derivation of velocity and acceleration in polar coordinates.
  • Learn about the relationship between radial and transverse components in polar motion.
  • Explore the implications of constant angular velocity on particle motion.
  • Investigate the conversion of polar coordinates to Cartesian coordinates for better visualization.
Students and educators in physics, particularly those focusing on mechanics and motion analysis, as well as anyone interested in the application of polar coordinates in real-world scenarios.
Rct33
I am asked to find the radial and transverse velocity and acceleration for a particle with polar coordinates r=e^t and \theta=t
Therefore let the position of the particle be \underline{r}=\underline{\hat{r}}e^t
$$\therefore \dot{\underline{r}}=\frac{\mathrm{d} }{\mathrm{d} t}(\underline{\hat{r}})e^t+\frac{\mathrm{d} }{\mathrm{d} t}(e^t)\underline{\hat{r}}$$
But \underline{\hat{r}}=\cos\theta\underline{\hat{i}}+\sin\theta\underline{\hat{j}}
$$\therefore\dot{\underline{r}}=\frac{\mathrm{d} \theta}{\mathrm{d} t}\frac{\mathrm{d} }{\mathrm{d} \theta}(\cos\theta\underline{\hat{i}}+\sin\theta\underline{\hat{j}})e^t+e^t\underline{\hat{r}}$$
$$=(-\sin\theta\underline{\hat{i}}+\cos\theta\underline{\hat{j}})e^t +e^t\underline{\hat{r}}$$
\therefore \underline{\hat{r}}=e^t\underline{\hat{\theta}}+e^t\underline{\hat{r}}
This is the particles velocity, the acceleration is given by:
$$\ddot{\underline{r}}=\frac{\mathrm{d} }{\mathrm{d} t}(\underline{\hat{\theta}}e^t+\underline{\hat{r}}e^t)$$
$$=\frac{\mathrm{d} }{\mathrm{d} t}(\underline{\hat{\theta}})e^t+\frac{\mathrm{d} }{\mathrm{d} t}(e^t)\underline{\hat{\theta}}+\frac{\mathrm{d} }{\mathrm{d} t}(\underline{\hat{r}})e^t+\frac{\mathrm{d} }{\mathrm{d} t}(e^t)\underline{\hat{r}}$$
$$=\frac{\mathrm{d} \theta}{\mathrm{d} t}\frac{\mathrm{d} }{\mathrm{d} \theta}(-\sin\theta\underline{\hat{i}}+\cos\theta\underline{\hat{j}})e^t+e^t \underline{\hat{\theta}}+e^t\underline{\hat{\theta}}+e^t\underline{\hat{r}}$$
$$=-e^t\underline{\hat{r}}+e^t\underline{\hat{\theta}}+e^t \underline{\hat{\theta}}+e^t\underline{\hat{r}}$$
$$=2e^t\underline{\hat{\theta}}$$
This is an acceleration in the transverse direction. But if \theta=t and r=e^t then why do I get an acceleration in the transverse direction, and not the radial direction? Is the transverse velocity not constant (I also got e^t\underline{\hat{\theta}} for transverse velocity, why is this?) Help is very much appreciated
I agree with you that something just doesn't seem right about all this. The first thing is that it seems, because ##{dθ \over dt} = 1##, that the angle between the velocity and the radius should go to zero as t gets large. But the formula suggests the angle is a constant ##θ + {\pi \over 4}##. So this looks highly suspect.
The second odd thing is that the acceleration is perpendicular to the radius. This seems to imply that the radial velocity is constant, that the acceleration is only adding to the rotational velocity of the vector, but as ##{dθ \over dt} = 1##, this looks doubly wrong.
After a lot of thought, I am convinced that these calculations are correct. The tangential velocity is proportional to the radius (why?), and the radial velocity is proportional to the radius (why?), so the angle of the velocity must be ##θ + {\pi \over 4}##.
And the acceleration, being not perpendicular to the velocity, lengthens and rotates it. And because the velocity is at a constant angle to the radius, the radial velocity is lengthened when the velocity is lengthened.
So the strangeness can be explained way.
Likes 1 person
I just checked that the calculations done are right by doing everything in Cartesian coordinates. Then the motion is given by
\vec{r}(t)=\exp t [\cos t \hat{x}+\sin t \hat{y}].
Since \hat{x} and \hat{y} are constant, you can easily do the derivatives wrt. t, and then you can find the components of velocity and acceleration simply by taking the dot products with the polar-coordinates orthonormal basis
\hat{r}=\cos t \hat{x} + \sin t \hat{y}, \quad \hat{\theta}=-\sin t \hat{x} + \cos t \hat{y}
along the trajectory. I admit, the solution is not so intuitive but correct :-).
Likes 1 person
This makes sense after thinking about it, thanks for your help! It is kinda simple now that you explained it too :p
