Velocity Using Parametric Equations
3 replies · 2K views
GreenPrint
An object moves in two dimensions according to the parametric equations x(t) = At^2 + Bt and y(t) = D cos(Et). The constants A, B, D, and E are A = 2 m/s^2, B = 3 m/s, D = 4 m, and E = 1 rad/s. What is the magnitude of the total velocity of the object at t = 3 s?
I'm not sure if I did this problem right. I plugged back in the constants
x(t) = 2 t^2 + 3 t
y(t) = 4 cos(t)
dx/dt = 4 t + 3
dy/dt = -4 sin(t)
dy/dx = dy/dt dt/dx = [-4 sin(t)]/[4 t + 3]
I thought that this was the velocity?
I then plugged in 3 for t and then plugged this into my calculator
[-4 sin(3)]/(12+3) and got about - .038 m/s but sense it said magnitude only I ignored the negative sign and put .038 m/s
I have the feeling I did this problem wrong. This is for my physics 2 course and is suppose to be a introductory physics course after taking physics 1 (non calculus based) and this is just suppose to be like calculus I based but parametric equations is a calculus 2 topic (in most american schools) and I'm in calculus 2 at the moment and haven't covered the topic yet and only have a brief understanding of it so I'm not sure
What is the magnitude of the vector [itex]\vec{v}=[v_x,v_y][/itex]?
Or, how do you evaluate the magnitude of a vector knowing its components?
And, [itex]\vec{v}=[v_x,v_y]=[\frac{dx}{dt},\frac{dy}{dt}][/itex]
Ah I thought so, so I plug in 3 into each of the derivatives square both of these values sum these squared values and then take the square root of the whole thing?
Yep
[itex]|\vec{v}_{t=3}|=\sqrt{\left[\left.\frac{dx}{dt}\right|_{t=3}\right]^2+\left[\left.\frac{dy}{dt}\right|_{t=3}\right]^2}[/itex]
