Verify Is Math Correct? Assumptions Correct?
  • Thread starter Duave
    Assumptions
16 replies · 3K views · last reply
Duave
Can someone please tell me if I have solved the problem? Is the math correct? Were the assumptions correct?
Thank you in advance
Show that:
I(B) = 44 uA
I(C) = 4.4 mA
V(CE) = 1.2 V
https://scontent-a.xx.fbcdn.net/hphotos-prn1/t1.0-9/1011057_10151937081760919_165466716_n.jpg
V(B) - V(BE) = V(E)
I(B) = V(B)/R(B)
I(B) = [Beta][I(B)]
The dotted lines were placed for clarity.
Part A
V(B) = 5V
V(BE) = 0.6V
V(B) - V(BE) = 5V - 0.6V
V(B) - V(BE) = 4.4V
R(B) = 100 x 10^3(ohms)
I(B) = [4.4V/100 x 10^3]
I(B) = 44 uA
I(C) = [Beta][I(B)]
I(C) = (100)(44 x10^-6)
I(C) = (4.4 mA)
V(C) - [I(C)][R(C)] = V(CE)
10V - (4.4 x 10^3(A))(2000(ohms)) = V(CE)
10V - (8.8(V)) = V(CE)
1.2V = V(CE)
Part B
Find Beta
(Beta)[I(B)] = I(C)
I(S){e^(V(BE)/V(T)] -1} = I(C)
I(S){e^(V(BE)/V(T)] -1} = (Beta)[I(B)]
Beta = [I(S)/I(B)]{e^(V(BE)/V(T)] -1}
Beta = [{[V(CC) - V(CE)]/[R(C)]*[e^{V(BE)/VT]}/I(B)]{e^(V(BE)/V(T)] -1}
Beta = [{[V(CC) - V(CE)]/[I(B)][R(C)]
Beta = [{[10V - 1.2V]/[44 x 10^-6(A)][2000]
Beta = 100
Looks good. But why do you calculate beta (with something calculated in (A)), if you can use it in (A)?
@mfb
I made a mistake. I know that beta is unitless.
My question to you is, if I erase the (A), would the statement then be COMPLETELY correct?
Thanks again
rude man said:
Where do you assume beta = 100? It can't be calculated except by assuming the answers a priori.
@ Rude Man
I understand what you mean. I was to answer the question below:
Suppose that the circuit shown in this thread goes into saturation. What is the MINIMUM value of β which would cause saturation?
Do my calculations answer this question? Do my final answers in bold answer it or do I need to give additional information?
Thanks again
Duave said:
@ Rude Man
Thanks again
In that case beta needs to be a bit more than 100.
I answered your other question by quoting your 1st post.
V(B) = 5V
V(BE) = 0.6V
V(B) - V(BE) = 4.4V
I(B) = 44 uA
I(C) = [Beta][I(B)]
No. A beta of 100 will not saturate the transistor.
I(C) = (4.4 mA)
No. See above comment.
It takes more than 4.4 mA to saturate the transistor.
I'll leave it here for the time being ...
@Duave: All the confusion here comes from the missing problem statement.
Please post the full, exact problem statement here, otherwise we keep on guessing what you are supposed to do.
I have to solve for I(B), I(C), and V(CE)
The whole problem statement for Part (a) is Literally:
Show that:
I(B) = 44 uA
I(C) = 4.4 mA
V(CE) = 1.2 V
I have to show calculations that prove that I(B) = 44 uA, that I(C) = 4.4 mA, and that V(CE) = 1.2 V.
Seriously, that's all that I was given.
The whole problem statement for Part (b) is Literally:
"Suppose that the circuit shown in this thread goes into saturation. What is the MINIMUM value of β which would cause saturation?"
Thanks again
Show that:
I(B) = 44 uA
I(C) = 4.4 mA
V(CE) = 1.2 V
Thanks again
OK, we caw summarize this as follows:
part (a) beta = 100 and your computatiuons are correct.
part (b) did you ever find the minimum beta?
@rude man
Thank you so much for your response:
Right now β = 100
iC/iB = β
iC = 4.4 mA
iB = 44 uA
4.4 mA/44 uA = β
100 = β
if VC drops to VCE then,
VC = 1.2V
IC(1.2V) = VC/RC
IC(1.2V) = 1.2V/2000(ohms)
IC(1.2V) = 0.6mA
if IB is fixed, then
IC/IB = β
0.6 mA/44 uA = β
13.64 = β
So, the minimum β = 13.64
Is this correct or am I still missing soemthing? Thanks again.
For this circuit Ib = (Vin - Vbe)/Rb = (5V - 0.6V)/100k = 44μA
The maximum collector current is equal to
Ic_max = (Vcc - Vcs(sat))/Rc ≈ Vcc/Rc ≈ 10V/2K ≈ 5mA
So if BJT current gain Hfe (β) will be larger than 5mA/44μA = 114 the BJT will enter saturation region.
Thanks Jony130
I can understand the max value you that you calculated, but does my minimum look okay or do I need to fix that?
But what this minimum Hfe value will represent? Because if you want Ic = 0.6mA for fixed base current (44μA), then you need to use a BJT with a Hfe equal to 13.64.
Jony130,
So does the collector branch always determine the minimum Hfe (β) that will cause saturation? That's right isn't? In this circuit, The collector determined the minimum saturation value.
Part b assumes eveything in the circuit stays the same except beta can rise.
So to compute the min. needed for saturation, use the same base current, multiply by beta, and let that product = the collector current needed to reduce the collector voltage to zero. Then solve for beta.
