Verify or refute the function is a solution to a PDE
  • Thread starter Thread starter docnet
    Function Pde
6 replies · 2K views · last reply
docnet
Verify or refute the functions are solutions to a PDE
##u(x)=\frac{1}{2}(x_1^2+x_2^2+...+x_n^2)##
Solution attempt:
We first write ##u(x)=\frac{1}{2}||x||^2## as ##u(x)=\frac{1}{2}(x_1^2+x_2^2+...+x_n^2)##
Operating on ##u(x)## with ##\Delta##, we have ##u(x)=\frac{1}{2}(2+2+...+2)## adding 2 to itself ##n## times.
So ##\Delta u(x)=n## and the function satisfies the first condition.
The outward unit normal field on the boundary of unit ball denoted ##\partial B_1(0)## is ##\nu=\left<x_1, x_2,...,x_n\right>##
The derivative of ##u## in the direction ##\nu## is given by ##D_{\nu}u=\frac{1}{2}(2x_1+2x_2+...+2x_n)=(x_1+x_2+...+x_n)##
So the function u does not satisfy the Neumann boundary conditions.
For the condition ##u=1## on the boundary of the unit ball, we consider the euclidian norm to be always equal to 1 by definition.
So the function ##u## satisfies the Dirichlet boundary conditions.
For the second one, u isn't equal to the euclidean norm.
For the first one, how do you know that the thing you wrote down doesn't add up to 1? If n=1, I think it does. Edit to add: actually I think you have computed the derivative in part 1 incorrectly.
I am not sure why ##u## does not equal the euclidian norm? ##u## is defined as the magnitude of vector ##\left<x_i\right>## squared. The boundary of a unit ball is an ##n## dimensional sphere, defined roughly as collection of points distance 1 from the origin. So every point on the boundary of the unit ball is a vector of length 1.
I am not sure what you mean.. I added 2 to itself n times because there are n identical terms in the form of ##x_i^2## in ##u(x)## then i factored out ##2## which cancels with ##\frac{1}{2}## leaving n.
I just used the chain rule. most terms cancel out giving ##(x_1+...+x_n)##
But isn't u equal to one half the norm squared?
To compute the directional derivative, you have to compute the total derivative (which depends on the coordinates of the point you are at), and then apply that matrix to the direction you care about.
Yes, it is. It just occurred to me I did not account for the factor of ##\frac{1}{2}##. thank you.
total derivative? i thought it was partial. i computed
##D_{\left<x_1+x_2+...+x_n\right>}(x_1^2+x_2^2+...+x_n^2)=##
##\partial_{x_1}\frac{1}{2}(x_1^2+x_2^2+...+x_n^2)+...+\partial_{x_n}\frac{1}{2}(x_1^2+x_2^2+...+x_n^2)=##
##x_1+...+x_n##
You have [tex] \frac{\partial u}{\partial \nu} = \boldsymbol{\nu} \cdot \nabla u[/tex] where [itex]\boldsymbol{\nu}[/itex] is the outward normal, which here is [itex]\mathbf{x}/\|\mathbf{x}\|[/itex]. Thus [tex] \frac{\partial u}{\partial \nu} = \sum_{i=1}^n x_i \frac{\partial u}{\partial x_i}[/tex] since [itex]\|\mathbf{x}\| = 1[/itex].
Thank you, that makes sense
[tex] \frac{\partial u}{\partial \nu} = x_1^2+...+x_n^2=1[/tex]
which makes u a solution of the PDE problem.
