Verifying Calculations for 2g of NH4Cl: Low Yields Explained
  • Thread starter Thread starter mastiffcacher
    Calculations
The discussion revolves around the calculations and experimental results related to the synthesis of 2 grams of ammonium chloride (NH4Cl) using hydrochloric acid (HCl) and ammonium hydroxide (NH4OH). Participants explore the theoretical yields, actual yields, and potential reasons for low yields in the experiment.
  • Experimental/applied
  • One participant calculated that 2 grams of NH4Cl corresponds to 0.037519 moles and determined that 6.25 mL of 6M HCl and 6.25 mL of 6M NH4OH were needed for the reaction.
  • Another participant noted that ammonium chloride can revert to HCl and NH3 under mild conditions, suggesting that this could contribute to yield loss.
  • A question was raised about whether the loss during drying could account for the low yield observed in the experiment.
  • Participants discussed the conditions used for the reaction, including the drying process and the temperature applied, which may have influenced the results.
  • One participant confirmed that the calculations appeared correct but suggested that sublimation of the solid could be a factor in the yield loss.
Participants generally agree that the calculations for the required volumes of reactants are correct, but there is uncertainty regarding the reasons for the low yield, with multiple potential explanations being discussed.
Participants did not reach a consensus on the specific causes of the low yield, and there are unresolved questions regarding the experimental conditions and potential errors.
mastiffcacher
Trying to make sure my calculations were correct. We were tasked to make 2 grams of NH4Cl. Our proposed method was using HCl and NH4ClOH. This was confirmed as our best way.
The way I figured it was that 2 grams of ammonium chloride was 0.037519 moles. We used 6M hydrochloric acid and 6M ammonium hydroxide for the reaction. I calculated that we needed 6.25 mL of each solution to make the 2 grams. Our results were horrible as we only made .186 g and .233 g in two different trials.
I am wondering if these amounts are correct at least theoretically. Does this reaction typically have this low of a percent yield? If it is usually this low of a yield, why might this be?
Chemistry news on Phys.org
When you try to dry ammonium chloride, it spontaneously reverts back to HCl and NH3 under suprisingly mild conditions... it evaporates.
So it should have produced 2 grams but the loss is great while drying?
What conditions did you use to produce and dry it?
We used 6.25 mL of 6M HCl and 6.25 mL of 6M NH4OH. Placed in beaker under hood. When vapors stopped from beaker, we moved to a hot plate se at ~250F. It took about 15 minutes or so for the resultant water to evaporate. This was done in my chem lab for school. I was working on a report and am trying to figure out what errors may have occurred. I just wanted to make sure that I did not miss something in my calculations and that 6.25 mL was the correct volume of 6M reactants to use. I also thought that my TA told us that this was the better reaction to run. Maybe she meant the easiest. If that is the correct volume, why is the loss so great?
Calculations are OK. The only thing I can think off - apart from some human error - is what was already signalled by Chemisttree, loss due to the sublimation of the solid.
13K
