Verifying Potato Weight: Hypothesis Testing and Beta Error Analysis
  • Context:
  • Thread starter Thread starter mathmari
    Beta Error
13 replies · 3K views
mathmari
MHB
Hey! :o
A vegetable trader sells potatoes in 5 kg bags. Since potatoes differ in size, it is difficult to ensure that in each bag are exactly 5 kg. The dealer claims that the average weight of the potatoes was 5 kilograms. This has to be checked with a sample.
The sample (n = 25) gives an average value of 5.2 kg and an empirical standard deviation of 0.5 kg. By that sample can we say that that the average weight of the potatoes in the bag differs from 5 kg? The significance level is 0.05.We have the following:
Null hypothesis ($H_0$): The average weight of the potatoes is 5 kg.
Alternative hypothesis ($H_1$): The average weight of the potatoes is not 5 kg, but 5.2kg.
Is this correct? (Wondering)
The Beta error is the possibility that the null hypothesis is hold although it is false.
Then it s asked the following:
How big is the Beta error?
a) 0,25
b) 0,05
c) 0,95
d) 0,1
e) cannot be given I have done the following:
We have that the significance level is 0.05.
So, $P(Z < z) = 0.05$ and we get a z-value of $-1.645$.
We convert this to an X-value: $5-1.645\frac{0.5}{\sqrt{25}}=5-1.645\cdot 0.1=4.8355$
Then we have the follwoing: $P(X > 4.8355) = P\left [z > \frac{3.069-5.2}{0.1}\right ] = P(z > -3.645)=1-P(x\leq -3.645$ , now from a Normal table we get $beta = 1-P(x\leq -3.645 = 1-0.00014=0.99986$.
I must have done something wrong, since this answer is not one of the choices. Bur what? (Wondering)
mathmari said:
Hey! :o
Hey mathmari! ;)
A hypothesis is not supposed to include a sample measurement - only a statement about the population that we want to test.
a) 0,25
b) 0,05
c) 0,95
d) 0,1
Since the alternative hypothesis is an inequality, shouldn't that be P(Z<z)<0.05 OR P(Z>z)<0.05? (Wondering)
Where or how did you get that z-value?
To say anything about beta, we basically need to know what the real distribution of the population is, so that we can estimate whether the null hypothesis holds. That distribution is not given is it? (Wondering)
So, the hypothesis doesn't say anything about the average weight of the potatoes, does it? Is the null hypothesis then:
"The weight of one single bag is equal to the average weight. So, the weight of one single bag is 5kg." ? (Wondering)
From the table we get the result $0.05$ for $z=-1.645$. Is this wrong? (Wondering)
So, we cannot say anything about beta, can we? (Wondering)
What additional information about the distribution do have to know to compute it? For example if the distribution is normal? (Wondering)
The null hypotheses is that the population mean $\mu$ is equal to a certain number.
The alternative hypothesis is that the population mean $\mu$ somehow differs from that certain number.
So we should have:
$$H_0: \mu = 5\text{ kg} \\ H_1: \mu \ne 5 \text{ kg}$$
This form of $H_1$ is called 2-sided, since the real population mean $\mu$ could be either higher or lower (from the word 'differs') than $5\text{ kg}$. (Nerd)
Ah. I see what you mean. This is the so called critical z-value for $\alpha=0.05$ of a 1-sided alternative hypothesis (like $H_1: \mu > 5 \text{ kg}$).
However, since we have a 2-sided alternative hypothesis, we should look up the z-value for $\frac\alpha 2=0.025$, which is $z^*=1.96$ ($z^*$ to denote the critical z-value).
To calculate $\beta$ we typically need the real $\mu$ and $\sigma$ of the population that should be such that the alternative hypothesis is satisfied.
With those we can calculate the probability $\beta$ that we keep $H_0$ even though the real population distribution matches the $H_1$ hypothesis. (Thinking)
So we should have:
Ah ok. I see! (Smile)
Ah ok. (Thinking)
We have that "The sample (n = 25) gives an average value of 5.2 kg and an empirical standard deviation of 0.5 kg.".
Do we not get from that that $\mu=5.2$ and $\sigma=0.5$ ? (Wondering)
The problem statement asks whether we the alternative hypothesis is true.
The way to do that is to calculate the z-score given by:
$$SE = \frac{\sigma}{\sqrt n} \\ z = \frac{\bar x - 5\text{ kg}}{SE}$$
where $\sigma$ is the empirical standard deviation (and not the standard deviation of the sample), and $SE$ is the so called standard error.
We didn't do that yet did we? (Wondering)
Well... the actual population mean is not given, so I don't think we can calculate $\beta$.
Alternatively, perhaps we're supposed to assume that the sample mean is somehow representative of the real distribution, which is a bit of a stretch... (Thinking)
If so we should assume that $\mu = 5.2\text{ kg}$ and $\sigma=0.5\text{ kg}$, after which we should calculate:
$$\beta = P\big((X < 5 + z^* \cdot SE) \land (X > 5 - z^* \cdot SE)\big)$$
or:
$$\beta = P\left(\left(Z < \frac{5 - 5.2}{SE} + z^*\right) \land \left(Z > \frac{5 - 5.2}{SE} - z^*\right)\right)$$
which is the probability that we keep $H_0$ even though the population distribution is assumed to be given by the sample mean and the empirical standard deviation.
or:
$$\beta = P\left(\left(Z < \frac{5 - 5.2}{SE} + z^*\right) \land \left(Z < \frac{5 - 5.2}{SE} - z^*\right)\right)$$
What is $z^*$ ? The one that you defined above, $z = \frac{\bar x - 5\text{ kg}}{SE}$ ? (Wondering)
No. $z^*$ is the so called critical z-value.
In this problem we have $z^* = 1.96$, which is in your table, and which is the most common critical z-value. (Nerd)
Ah ok. So, do we have the following? (Wondering)
\begin{align*}\beta &= P\left(\left(Z < \frac{5 - 5.2}{SE} + z^*\right) \land \left(Z < \frac{5 - 5.2}{SE} - z^*\right)\right) \\ & =P\left(\left(Z < \frac{0.2}{0.1} + 1.96\right) \land \left(Z < \frac{0.2}{0.1} - 1.96\right)\right) \\ & =P\left(\left(Z < 3.96\right) \land \left(Z < 0.04\right)\right) \\ & =P\left(Z < 0.04\right) \\ & =0.51595\end{align*}
Erm... (Blush)
That should be:
\begin{align*}
\beta &= P\left(\left(Z < \frac{5 - 5.2}{SE} + z^*\right) \land \left(Z > \frac{5 - 5.2}{SE} - z^*\right)\right) \\
& =P\left(\left(Z < \frac{-0.2}{0.1} + 1.96\right) \land \left(Z > \frac{-0.2}{0.1} - 1.96\right)\right) \\
& =P\left(\left(Z < -0.04\right) \land \left(Z > -3.96\right)\right) \\
& \approx P\left(Z < -0.04\right)
\end{align*}
(Thinking)
I like Serena said:
Erm... (Blush)
That should be:
\begin{align*}
\end{align*}
(Thinking)
Oh yes... (Blush)
So, the result is then $0.48405$, or not? (Wondering)
mathmari said:
Oh yes... (Blush)
That looks about right. (Nod)
And since it is not in the list of given answers, perhaps the answer should be "cannot be given" after all? (Wondering)
It must be so.
Thank you very much! (Happy)
For the record, this is what the distributions look like when trying to determine $\beta$.
\begin{tikzpicture}
%preamble \usepackage{pgfplots}
\pgfmathdeclarefunction{gauss}{3}{%
\pgfmathparse{1/(#3*sqrt(2*pi))*exp(-((#1-#2)^2)/(2*#3^2))}%
\begin{axis}[
no markers, domain=4.5:5.7, samples=100,
axis lines*=left, xlabel=$x$, ylabel=$p$,
every axis y label/.style={at=(current axis.above origin),anchor=south},
every axis x label/.style={at=(current axis.right of origin),anchor=west},
height=5cm, width=12cm,
xtick={5,5.2}, ytick=\empty,
enlargelimits=false, clip=false, axis on top,
grid = major
\addplot [fill=cyan!30, draw=none, domain=4.5:5.19] {gauss(x,5.2,0.1)} \closedcycle;
\addplot [fill=red!30, draw=none, domain=5.19:5.7] {gauss(x,5,0.1)} \closedcycle;
\addplot [fill=red!30, draw=none, domain=4.5:4.81] {gauss(x,5,0.1)} \closedcycle;
\addplot [very thick,cyan!50!black] {gauss(x,5,0.1)};
\addplot [very thick,cyan!50!black] {gauss(x,5.2,0.1)};
\draw [yshift=-0.6cm, latex-latex](axis cs:5,0) -- node [fill=white] {$1.96\sigma$} (axis cs:5.19,0);
\node at (axis cs:5.12, 1.1) {$\beta$};
\node at (axis cs:4.78, 0.16) {$\alpha/2$};
\node at (axis cs:5.22, 0.16) {$\alpha/2$};
\node at (axis cs:5, 4.3) {$N(5,SE)$};
\node at (axis cs:5.2, 4.3) {$N(\mu,SE)$};
\end{axis}
\end{tikzpicture}
The light-red part is $\alpha/2=0.025$, which is where we reject the null hypothesis.
And the cyan part is $\beta \approx 0.48$ where we keep the null hypothesis even though it should have been rejected based on the actual population distribution (which is usually not known). (Thinking)
