Verifying Trigonometric Identities
In summary, fogmomjazz is having difficulty with a particular trig identity and is seeking help from the forum.
fogmomjazz
First I wanted to say hello, that I'm new to the forum, and very glad to have found you!
I am having a terrific time with verifying my trig identities. I have done ALL odd probs in my text, and am repeating them. The problem that I am having is that I do not see a clear path from one side of the expression to the other side.
My methods are crude, and I always start by writing everything in terms of sin and cos. Then I like to eliminate fractions, but those 2 methods are not proving to be much help.
With the simple 2 or 3 step proofs, I can do well, but when I have to do more than that, I'm like a 3 year old with a TI-84. I might be able to do some stuff with it, but it gets me nowhere, and I don't understand what Its doing.
So here is one problem that I am working on. I have the solution manual for my text, so I use that for moving along, but I would appreciate ANY input that you might think is helpful for me.
cosxcotx
-------- - 1 = cscx
1-sinx
I know some of you might just peek at it, and know how to do it, but I have wasted almost 2 pages of paper writing and re-writing this problem! help me please
cosx cosx
sinx
----------- - 1
1-sinx
-1 being changed to 1-sin^2x, and reduced to:
cosx cotx - (1-sinx)
1-sinx
this is where I get lost. I can look at the solution manual and get their resolution, but I still don't look at it and see anything.
Thanks for having such a helpful forum, Jenny
From your initially given identity, you should obtain steps:
[tex] \[
\begin{array}{l}
\frac{{\cos (x){\textstyle{{\cos (x)} \over {\sin (x)}}} - (1 - \sin (x))}}{{1 - \sin (x)}} \\
\frac{{{\textstyle{{\cos ^2 (x)} \over {\sin (x)}}} - 1 + \sin (x)}}{{1 - \sin (x)}}\quad thenUsePythag.Identity, \\
\frac{{{\textstyle{{1 - \sin ^2 (x)} \over {\sin (x)}}} - 1 + \sin (x)}}{{1 - \sin (x)}} \\
\end{array}
[/tex]
and the rest is slightly involved but relatively simple algebra.
Hi fogmomjazz! Welcome to PF! :smile:
(btw, don't abbreviate cosec to csc - it's too difficult to read.)
First, don't have lines over lines. If you have two things on the bottom, put them next to each other, on the same line, or you'll get confused and make mistakes.
So you should write your
cosx cosx
sinx
----------- - 1
1-sinx​
as: [tex]\frac{cosx.cosx}{sinx(1 - sinx)}\,-\,1.[/tex]
That's much clearer, and you can then see how to best rewrite the 1:
[tex]\frac{(cosx.cosx - sinx(1 - sinx))}{sinx(1 - sinx)}[/tex]
= [tex]\frac{(cosx.cosx - sinx + sinx.sinx))}{sinx(1 - sinx)}[/tex]
= … can you see where to go from there … ? :smile:
You must realize that the ordinary textbook abbreviation for cosecant of x IS csc(x), and this is also the most common abbreviation used during classtime instruction.
Multiply top and bottom of the the first term on the left hand side by 1 + sin(x) to get:
[cos(x)*cot(x) + cos^2(x)] / [1-sin^2(x)] = [cos(x)*cot(x) + cos^2(x)] / [cos^2(x)] (by pythag identity) = cot(x)/cos(x) + 1 = csc(x) + 1
Now subtract the one and you get the what you're looking for.
Spelling or txtg?
Goodness, that's horrible! :frown:
All the other trig abbreviations can be pronounced the way they're written (cos sin tan sec cot), but how do you pronounce csc?
This isn't texting!
I thought you Americans like to spell words the way they're pronounced? :confused:
Still, if that's the American way, I suppose fogmomjazz had better carry on doing it …
1. What is the purpose of verifying trigonometric identities?
The purpose of verifying trigonometric identities is to prove that two expressions involving trigonometric functions are equivalent. This is important in mathematics and science as it allows for simplification of complex equations and aids in solving problems involving trigonometric functions.
2. How do you verify a trigonometric identity?
To verify a trigonometric identity, you must manipulate one side of the equation using algebraic and trigonometric identities until it is equal to the other side. This process may involve simplifying, factoring, or using trigonometric identities such as the Pythagorean identities or double-angle identities.
3. What are the common mistakes made when verifying trigonometric identities?
Some common mistakes made when verifying trigonometric identities include forgetting to distribute terms, making algebraic errors, and not using the correct trigonometric identities. It is important to double-check each step and to have a good understanding of the properties and identities of trigonometric functions.
4. Can trigonometric identities be verified using a calculator?
No, trigonometric identities cannot be verified using a calculator. Calculators use approximations for trigonometric functions, so they may not give the exact values needed to verify an identity. It is important to use algebraic manipulation and trigonometric identities to verify an identity instead of relying on a calculator.
5. Why is it important to verify trigonometric identities?
Verifying trigonometric identities is important because it allows us to simplify complex equations and solve problems involving trigonometric functions. It also helps to build a better understanding of trigonometry and the relationships between different trigonometric functions. In fields such as physics and engineering, verifying identities is crucial for accurately solving problems and making calculations.
  • Precalculus Mathematics Homework Help
