Very Very Basic Numeracy Question - I'm Having a Dumb Moment?
  • Thread starter Thread starter Physics Enemy
    Moment
The discussion revolves around the Doppler shift and its implications for frequency measurements. The original poster presents a question regarding the fluctuation of temperature (T) in relation to frequency accuracy, specifically comparing frequencies to a precision of 1 part in 10^15.
  • Participants explore the relationship between frequency differences and temperature fluctuations, questioning the implications of the precision level. There is a focus on understanding the equation presented and its dimensional consistency.
Participants are actively engaging with the concepts, seeking clarification on the relationship between frequency and temperature. Some have offered insights into the nature of the frequency difference, while others are questioning the assumptions made in the original equation.
There are discussions about the appropriateness of the formula used and the implications of using constants in the context of the problem. Participants are also addressing potential misunderstandings related to the terminology and units involved.
Physics Enemy
Hi,
Basically the question is about doppler shift. The formula is:
(f2 - f1)/f1 = -kT ; f1 = Freq in object rest frame, f2 = Freq in lab frame
The Q: Often, frequencies are compared to 1 part in 10^15. In order to make use of this level of accuracy, to what extent can T fluctuate?
I think I'm having a serious dumb moment. Does this mean (f2 - f1) is at least 1/10^15? i.e.) We can't discern less than that? But then what do I do; are they expecting a % error?
Thanks.
Physics Enemy said:
Hi,
There is a problem with your equation, since the units do not match. The left side is unitless, while kT has units of energy.
It means |f2-f1| is comparable to f1/1015, or f2/1015.
Sorry - The k is just a constant I put in, it's actually various quantities bundled together. So the dimensions do turn out to be correct. I just wanted to simplify and focus on the Q.
This is the key point and thanks for your answer. Could you perhaps expand on this? At the moment it just seems a little random to me and I don't understand it in laymans terms. And why is it one or the other (f1/10^15 'or' f2/10^15) ?
Thanks!
Okay, that makes more sense. (The letter k is also used for Boltzmann's constant, which often appears in equations with temperature in the form kT, so I wrongly assumed you meant that.)
Thanks!
Well, in layman's terms, it means the difference |f2-f1| is a lot smaller than f1. How much less? Well, it's 1/1015 times smaller than f1. We could also say that f2 is 0.999999999999999*f1, or maybe it's 1.000000000000001*f1 -- depending on whether f1 or f2 is larger than the other. Either way, it doesn't matter whether |f2-f1| is being compared to f1 or f2, because f1 and f2 are so very nearly equal to each other.
Or, put another way, the ratio
|f2 - f1| / f1 = 1/1015
Yes you're right, it was sloppy of me. :)
Thanks, I'm happy with this. So therefore:
1/10^15 = Constant * (Variation in T)
Variation in T = Some Number
So it's not a %, just +/- this number. Correct?
Yes, correct.
Thank you RedBelly. :-)
24K
  • · Replies 0 ·
