Visualizing the Dot Product Inequality of a, b & c in R^d
shybishie
Suppose I have three vectors a,b and c in R^d, And, I have that a.b < c.b(assume Euclidean inner product). What are the ways to visualize relation between a,b and c geometrically? I realize this is slightly open-ended, but am looking for insight here. Thanks in advance.
PS: I have a thought or two, but I'd like to hear feedback before I give my view of the situation.
\vec{a} \cdot \vec{b} &lt; \vec{c} \cdot \vec{b} can be interpreted geometrically as \vec{a} having less of a component in the direction of \vec{b} than does \vec{c}. Or \vec{a} has a more negative component than \vec{c}.
Thank you, markly. In retrospect, I should have framed this question to be less trivial sounding than it came out.
The dot product \vec{a} \cdot \vec{b} can be visualized as a rectangle (see orange rectangle http://www.ies.co.jp/math/java/vector/naiseki_e/naiseki_e.html" ) having sides of length |\vec{a}| and |\vec{b}| \mathrm{cos(\alpha)}.
This is because \vec{a} \cdot \vec{b} = |\vec{a}| \cdot |\vec{b}| \mathrm{cos(\alpha)}
##\textbf{Exercise 10}:## I came across the following solution online: Questions: 1. When the author states in "that ring (not sure if he is referring to ##R## or ##R/\mathfrak{p}##, but I am guessing the later) ##x_n x_{n+1}=0## for all odd $n$ and ##x_{n+1}## is invertible, so that ##x_n=0##" 2. How does ##x_nx_{n+1}=0## implies that ##x_{n+1}## is invertible and ##x_n=0##. I mean if the quotient ring ##R/\mathfrak{p}## is an integral domain, and ##x_{n+1}## is invertible then...
The following are taken from the two sources, 1) from this online page and the book An Introduction to Module Theory by: Ibrahim Assem, Flavio U. Coelho. In the Abelian Categories chapter in the module theory text on page 157, right after presenting IV.2.21 Definition, the authors states "Image and coimage may or may not exist, but if they do, then they are unique up to isomorphism (because so are kernels and cokernels). Also in the reference url page above, the authors present two...
When decomposing a representation ##\rho## of a finite group ##G## into irreducible representations, we can find the number of times the representation contains a particular irrep ##\rho_0## through the character inner product $$ \langle \chi, \chi_0\rangle = \frac{1}{|G|} \sum_{g\in G} \chi(g) \chi_0(g)^*$$ where ##\chi## and ##\chi_0## are the characters of ##\rho## and ##\rho_0##, respectively. Since all group elements in the same conjugacy class have the same characters, this may be...
