Volume of a rectangle by cross-sections
  • Thread starter Thread starter brushman
    Rectangle Volume
3 replies · 10K views · last reply
brushman
There is no specific problem, I'm just confused after reading the chapter.
Consider a pyramid 3 m high with a square base that is 3 m on a side. The cross section of the pyramid perpendicular to the altidude x m down from the vertex is a square x m on a side.
Now I understand the volume is,
[tex] \int_{a}^{b} A(x) dx = \int_{0}^{3} x^2 dx = 9[/tex]
but then I get confused. How would the volume of a rectangle with the same square base, using the same method, be any different?
edit: Thanks, it makes much more sense to me now.
First of all, there is no such thing as the "volume of a rectangle." If you mean a rectangular prism, then the volume will be different. A rectangular prism with the same square base and height would have a volume of 27 cubic units.
[tex]V_{rectangular \ prism} = bh.[/tex]
[tex]V_{pyramid} = \frac{bh}{3}.[/tex]
(where b = area of base)
Thanks Rasko. Indeed I meant rectangular prism.
I know that the volume of a rectangular prism is just the area of the base times height, but I'd like to know the volume by the method of slicing such as in my example. That way, I can compare the two to help my understanding.
In the pyramid integration, x varies from 0 to 3. However, each cross section of a rectangular prism has the same base. So you would have instead:
[tex]\int_0^3 (3)^2 dx[/tex]
