Volume of Cylindrical Shells: y = 4x - x^2, y = 3; about x = 1
  • Thread starter Thread starter sarah22
    Cylindrical
The discussion revolves around finding the volume generated by rotating the region bounded by the curves y = 4x - x^2 and y = 3 about the line x = 1 using the method of cylindrical shells. Participants are exploring the appropriate limits of integration and the correct application of the shell method.
  • Participants discuss the limits of integration, with some suggesting that the correct range should be from 1 to 3 rather than 0 to 1. There is also confusion regarding the formula for the cylindrical shell method, with references to potential mixing of methods.
There is an ongoing examination of the limits of integration and the formula used for the cylindrical shell method. Some participants have offered corrections and clarifications, while others are reflecting on their misunderstandings. The discussion appears to be productive, with participants actively engaging in correcting each other's reasoning.
Participants are grappling with the implications of integrating with respect to the x-axis and the relationship between the curves involved. There is mention of a specific answer from the textbook that prompts further questioning about the integration limits.
sarah22
Use the method of cylindrical shells to find the volume generated
by rotating the region bounded by the given curves about the
specified axis. Sketch the region and a typical shell.
int(2*pi*(1-x)*(3-4*x+x^2), x = 0 .. 1) = 11pi/6
This is the only problem on the book that I can't really understand. The correct answer is 8pi/3 according on the odd answers on the back page.
Increasing the upper limit to 2 gives the correct answer. But why? Isn't it I'll just integrate until 1 so I can get a y = 3. Why 2?
Your limits of integration are wrong. The region over which you are integrating is [1, 3], not [0, 1].
I get 8pi/3 with this integral:
-2\pi \int_1^3 (x - 1)(x^2 - 4x + 3)dx
I think the mistake you are making is in the formula that you are integrating. It seems like you were thinking washers while using the shell equation.
The general equation to use for the shell method is
2\pi\int R dx(dx can change depending on which variable you are integrating with respect to, but in this case it would be dx).
Where R is the distance from the axis of rotation. In this case, the R isn't 3-f(x), just f(x).
Sarah's integrand was correct. Her only problem was she had the wrong limits of integration.
No, this is not correct. The volume of a cylindrical shell is 2pi * radius * height * thickness. Your formula completely omits the height of the shell.
why would the limits of integration be from 1 to 3 if you are integrating with respect to the x axis?
nevermind, I've got it! sorry for my faulty answer and thank you for correcting my mistake.
No problem. We all make mistakes at least once in a while...
oh... now i noticed my problem.
4x - x^2 = 3
0 = x^2 - 4x + 3
0 = (x-3)(x-1)
x = 1 and 3
Tiredness really made my brain crazy.
  • · Replies 21 ·
