Volume Hypersphere: 4D Sphere Equation
  • Context: High School
  • Thread starter Thread starter Einstein's Cat
    Volume
The discussion revolves around the equation for calculating the volume of a four-dimensional sphere, or hypersphere, exploring the concept of volume in higher dimensions and the mathematical implications of such definitions.
  • Some participants question the definition of volume in the context of a hypersphere, with one suggesting that volume refers to the extent of space occupied, measured in cm4.
  • Another participant clarifies that while the volume of a hypersphere is analogous to the volume of a sphere, it is more accurately described as the 4-dimensional Lebesgue measure, which is measured in cm3.
  • A participant shares a detailed explanation involving the geometric construction of a 4-ball through the revolution of a 3-ball, referencing Archimedes’ method to derive the volume using centers of mass and solid of revolution techniques.
  • The calculation presented involves subtracting the volume of a revolved cone from that of a revolved cylinder to arrive at the volume of the 4-ball, leading to a specific formula involving π and R.
Participants express differing views on the definition and measurement of volume in higher dimensions, indicating that the discussion remains unresolved with multiple competing interpretations of what constitutes volume in the context of a hypersphere.
The discussion highlights ambiguities in terminology and measurement units when transitioning from 3-dimensional to 4-dimensional geometry, as well as the reliance on geometric constructions and historical methods for volume calculation.
Einstein's Cat
What is the equation used to calculate the volume of a four- dimensional "sphere," or hypersphere?
Mathematics news on Phys.org
Einstein's Cat said:
Thank you! And I believe volume to be the extent of space the hypersphere would occupy with units cm^4. Please correct me if I'm wrong.
You're not wrong, but the situation is ambiguous. Consider the usual sphere. The volume has unit ##cm^3## and its area has units ##cm^2##. When we get to the hypersphere, the number analogous to the surface area is the volume and is measured in ##cm^3##. What you want is the number analogous to the volume and which is measured in ##cm^4##. I understand completely the desire to call this volume. Mathematicians call it the 4-dimensional Lebesgue measure.
here are some notes i wrote on this topic:
just as a 3 ball is swept out by revolving half a disc around a line, so a 4 ball is generated by revolving half a 3 ball.
moreover the volume of the solid of revolution can be computed by knowing where the center of mass is. then we can
use Archimedes’ trick to do a calculation that Archimedes could have done. Namely he showed
that the volume of half a 3-ball equals the difference of the volumes of a cylinder minus that of a
cone. Now the center of mass of a cylinder is obviously half way up, and Archimedes knew that
just as the center of mass of a triangle is 1/3 of the way up from the base, the center of mass of a
cone is ¼ the way up from the base.
Thus we can use centers of mass and subtraction to get the volume of a 4-ball. I.e. a cylinder of
height R and base radius R has center of mass at height R/2, and volume πR^2.R, so revolving it
around an axis at its base gives 4 dimensional volume of 2π(R/2).πR^2.R = π^2.R^4. Now the
inverted cone of height R and base radius R has center of mass at distance ¼ of the way from its
base, hence distance (3R/4) from the axis, and volume (1/3)πR^2.R. Thus revolving it generates
a 4 dimensional volume equal to (2π)(3R/4).(1/3)πR^2.R = (1/2)π^2.R^4. Subtracting the
volume of the revolved cone from that of the revolved cylinder, gives the 4 dimensional volume
of the revolved half 3-ball, i.e. the volume of the full 4-ball as π^2.R^4 - (1/2)π^2.R^4 =
(1/2)π^2.R^4.
  • · Replies 16 ·
