Volume of revolution around the y-axis
The discussion revolves around finding the height and volume of a bowl created by rotating a piecewise function around the y-axis. The function is defined in two segments, with one segment involving the arcsine function. Participants are exploring the implications of this rotation and the correct setup for calculating volume.
  • Mixed
  • Participants are grappling with the correct interpretation of the height derived from the arcsine function and questioning the validity of their integral setups for volume calculation. There are discussions about using cylindrical shells versus disks for the volume calculation, and some participants are attempting to clarify the boundaries and regions of integration.
There is an active exploration of different methods for calculating volume, with some participants suggesting corrections to integral setups and questioning assumptions about the regions being revolved. Guidance has been offered regarding the use of the shell method and the importance of accurately defining the height and radius in the integrals.
Participants note that the problem statement may lack clarity, leading to confusion about the regions of integration. There are also references to curriculum constraints, indicating that participants may be limited in their exposure to certain methods of volume calculation.
Kqwert
Hello,
a bowl is created when rotating the function
f(x) =<br /> \begin{cases}<br /> 0, &amp; 0 \leq x \lt 6 \\<br /> (12/\pi)arcsin(x-6), &amp; 6\leq x \leq 7<br /> \end{cases}
around the y-axis. Find the height (h) and the volume (V) of the bowl.
So, I graphed the problem and found the height to be 6 (maximum y-value from the arcsin function). Apparently this is wrong. Why?
For the volume, I considered the integrals
<br /> \int_0^6 2\pi(6-0)x \, dx and 2\pi \int_6^7 (2/\pi)arcsin(x-6)x \, dx
and then adding them together. Where did I go wrong?
Kqwert said:
Hello,
Why do you think the height is wrong? The max. value from the arcsin function is 1, and the max. value from 12/pi arcsin(x - 6) is attained when x = 7.
The first integral doesn't make sense, nor does adding them together.
You don't have the radius right -- it should be x + 6.
Apparently you are using shells to get the volume. Start with a reasonably accurate sketch of the region that will be revolved. This will be a roughly triangular region. A typical area element is a thin vertical strip going from the x-axis to the arcsine curve. When this strip is revolved around the y-axis, it forms a thin shell. What is the volume of this shell volume element?
For both of the integrals or only the last one?
I've edited my earlier post, so take a look at it again. Your first integral doesn't make any sense.
The area bounded by the red and green lines are our area, right? (see thumbnail) If so, then from x = 6 to x = 7 the volume should be
\int_6^7 2\pi(6-(12/\pi)arcsin(x-6))(6+x) \, dx
Correct..?
Correct..?
Looks good to me...
Mark44 said:
Looks good to me...
Thanks! but what about the "center" of the bowl? i.e. 0 < x < 6. I guess I can solve this without integration, but how do I solve it w integration?
As I understand the problem, the bottom of the "bowl" is the plane formed from rotation the x-axis around the y-axis. Using the shell method, the region of integration is bounded by the lines x = 6, x = 7, and the curve. The shells are generated from thin strips between x = 6 and x = 7, so those are the limits of integration.
If this isn't the region of integration, but is instead the region bounded by the lines x = 6, y = 6, and the curve, then revolving that region around the y-axis gives a whole different solid of revolution, with a different volume. Is there a picture in your textbook of what the solid should look like?
No, it´s just given as I described in the first post.
The problem statement as posted isn't clear to me. I've been assuming that the sort of triangular region bounded by the x-axis, the line x = 7, and the curve is revolved around the y-axis. This would make a figure whose outer surface is a cylinder and whose inner surface is concave.
The integral you set up made me think that's what the solid is.
If the inner surface looks the same as the outer surface, then your first integral in post #1 looks fine, but the second integral doesn't. You are apparently using thin vertical strips, but between x = 6 and x = 7, your strips run from the x-axis up to the arcsine curve, which is wrong. They should instead run from the curve up to the line y = 6.
But wouldn't the area between the line y = 6 and the arcsin curve, between x = 6 and x = 7, be the integral in post #5?
The center is a standard cylinder. You probably learned how to compute its volume years before you studied calculus----it is just high-school geometry. In any case, just about every calculus textbook ever written will have sections in which such simple volumes are computed by integration.
Yeah, still get the wrong answer though, not sure if I am computing the correct volume.
Yes, and the total volume would be that plus the volume of the cylinder in the middle.
I'm a bit late to this thread, but surely wouldn't the natural way to set up this problem be using disks and a dy integral:
$$V = \int_0^6 \pi \left ( 6+\sin(\frac{\pi }{12}y)\right)^2~dy$$
Same thought occurred to me, as well.
In the curriculum we have only been through the disk method for rotation around the x-axis and cylindrical shells for rotation around the y-axis.
So, what is stopping you from using either one on this problem?
You have seen both methods, and there is no good reason for limiting yourself to only one kind for any given problem.
Correct..?
This is even later to the thread.
Here you have the correct height for a shell,
## \left(6-\frac{12}{\pi}\arcsin(x-6)\right)##​
but the radius for a shell is ##\ x\ ## as you had originally.
This gives the following for the volume generated by the portion of the function lying between x=6 and x=7.
## \displaystyle{\int_6^7} \left(2 \pi \left(6-\frac{12}{\pi}\arcsin(x-6)\right)(x)\right) \, dx ##
Thanks!
but what about the inner portion of the bowl? i.e. from 0 < x < 6. Is it pi*6^3..?
Kqwert said:
Thanks!
From Mark44 (post #10):
Mark44 said:
If the inner surface looks the same as the outer surface, then your first integral in post #1 looks fine, ...
So, the integral ##\displaystyle\ \int_0^6 2\pi(6-0)x \, dx\ ## gives the volume swept out by (height −ƒ(x)) for 0 ≤ x ≤ 6, where the height is 6 units. That is ##\ 6^3\pi\ ## as you asked.
  • · Replies 105 ·
10K
