Von Neumann Analysis: Refresh Numerical Science | Any Help Appreciated
1 reply · 2K views
liquidFuzz
I'm trying to refresh some numerical science stuff. Von Neumann analysis, if I take a slimmed down equation, convection. [tex]\frac{∂u}{∂t}+a ∇ u =0[/tex] If I'm using Euler forward, [tex]\frac{u^{n+1}-u^n}{\Delta t}+\frac{a}{2h} \left( u_{j+1}^n -u_{j-1}^n \right) =0[/tex] For [itex]\hat{u}^n = G^n\hat{u}^0[/itex] a growth factor [itex]|G|\leq1[/itex] is sufficient. This gives, [tex]\frac{u^{n+1}-u^n}{\Delta t} + \beta h \left( \frac{u_{j+1}^n-2u_j^n + u_{j-1}^n}{h^2} \right)[/tex] With the smallest possible diffusion but still stable, [itex]\beta \geq \frac{a}{2}[/itex] becomes [itex]\beta = \frac{a}{2}[/itex]. If this is plugged into the equation, [tex]\frac{u^{n+1}-u^n}{\Delta t} + \frac{a}{2h} \left( {u_{j+1}^n-2u_j^n + u_{j-1}^n} \right)[/tex] Now, according to some old notes I have the result is, [tex]\frac{u^{n+1}-u^n}{\Delta t} + \frac{1}{h} \left( {au_j^n -a u_{j-1}^n} \right)[/tex] Well this is somewhat vague for me. Specially the last step where the defraction term is finalised.
Any pointers of help would be appreciated, specially that last step.
I faintly remember that sometimes you could simplify things using a Taylor series going forward in j and a taylor series going backwards in j, then subtracting (or adding) one from the other. At least something along those lines. Considering the j-1 term remained, I'd consider doing the taylor series over the j+1 term (eq1) and the j term (eq2) and then multiplying eq2 by a factor of 2 and then adding (or subtracting) eq1 from eq2 and see what happens. You can probably ignore higher order terms which are negligible (or your only looking at a first order scheme).
