Estimating Speed Using Work and Energy Equations
  • Thread starter Thread starter chaostheory1
The discussion focuses on estimating the speed of a race car using the work-energy principle, specifically the equations W=KE and KE=(mv^2)/2. A 1000 kg race car skidded 100 m on a wet concrete road with a friction coefficient of µ = 0.55 before colliding with a guardrail. The calculations revealed a kinetic energy of 420,500 Joules, leading to confusion regarding the feasibility of this energy in relation to the braking force. Participants clarified that the work done by friction must be calculated to accurately determine the initial speed of the vehicle.
  • Understanding of the work-energy theorem
  • Familiarity with kinetic energy calculations
  • Knowledge of frictional force equations
  • Basic principles of Newtonian mechanics
  • Learn how to calculate frictional force using the equation F_friction = µ * m * g
  • Study the work-energy theorem in depth, focusing on its application in collision scenarios
  • Explore the relationship between work, energy, and speed in mechanical systems
  • Practice solving problems involving braking distances and initial speeds in physics
Students studying physics, particularly those focusing on mechanics and energy concepts, as well as educators seeking to clarify the work-energy principle in practical scenarios.
chaostheory1
I have honestly been trying to figure this problem out for over an hour now, and every time I try to solve for KE, I get a ridiculously high number.
A race car having a mass of 1000 kg was traveling at high speed on a wet concrete road under foggy conditions. The tires on the vehicle later were measured to have µ = 0.55 on that road surface. Before colliding with the guardrail, the driver locked the brakes and skidded 100 m, leaving visible marks on the road. The driver claimed not to have been exceeding 65 miles per hour (29 m/s). Use the equation W=KE to estimate the driver's speed upon hitting the brakes.
W=KE
KE=(mv^2)/2
Every time I try to substitute and solve for KE, I'm getting a workload of over 300,000 N for the brakes, obviously impossible.
First of all, why is it "obviously impossible"? Secondly, how exactly are you getting that number? (i.e. show your work)
Show exactly what you are doing.
One formula you didn't list is the one you need to compute the work done by friction. What would that be?
Ok,
KE=(.5)(mv^2)
KE=(.5)(1000 kg * (29 m/s)^2)
KE=420,500 N
W=KE
How can I possible have 420,500 N of work done by brakes?
Or am I doing this wrong...
Since the force that stopped the car was frictional; won't I have to calculate the frictional force using the Newton weight of the car? And use the frictional force in the KE and Work formulas?
Work is not just equal to K.E.
The work-energy theorem says:
W = delta K.E. = [1/2 mv(final)^2] - [1/2 mv(initial)^2]
chaostheory1 said:
Ok,
KE=(.5)(mv^2)
KE=420,500 N
W=KE
The unit of work/energy is Joules, not Newtons. And why do you think that that is an unreasonable amount of energy, or that brakes can't handle it? (Note that you don't need to calculate this energy to solve the problem.)
Absolutely. What does the friction force equal? (Symbolically, not numerically.) Set the work done by friction equal to the initial KE, then solve for the speed.
  • · Replies 17 ·
  • · Replies 19 ·
