A Wald's Abstract Index Notation: Explaining T^{acde}_b
madsmh
TL;DR Summary
Confusion by the abstract index notation introduced in Wald's General Relativity.
In the second paragraph on page 25 of Wald's General Relativity he rewrites T^{acde}_b as g_{bf}g^{dh} g^{ej}T^{afc}_{hj} . Can anyone explain this? I am confused by the explantion given in the book. Especially puzzling is that the inverse of g seems to be applied twice, which I can't make sese of.
Mads
The inverse metric is applied twice to raise the last two indices. The metric is used once to lower the second index.
Also note that the index horizontal placement is important.
This isn't particularly to do with abstract index notation - it applies in all tensor index notations. You do need to pay attention to which index is being contracted over and the order of indices is important. But all that's happening here is that the metric is being used to lower two of the indices and the inverse metric is being used to raise one. That's just what the metric does. Just as the metric in ##g_{ab}v^b## lowers the ##b## to give you the one form ##v_a##, the metric applied to any tensor lowers the repeated index - so ##g_{ad}T^{bcdefg}## lowers the ##d## to give you ##T^{bc}{}_a{}^{efg}##. Note that the repeated index ##d## was replaced with the other index on the metric because we summed over the dummy index.
In the cited section Wald is just randomly lowering a couple of indices and raising one to show you can do it to multiple indices at once.
Quote my post to see a way to do index notation with correct positioning in ##\LaTeX##.
Likes madsmh and cianfa72
Lowering one and raising two.
Likes cianfa72 and Ibix
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
From $$0 = \delta(g^{\alpha\mu}g_{\mu\nu}) = g^{\alpha\mu} \delta g_{\mu\nu} + g_{\mu\nu} \delta g^{\alpha\mu}$$ we have $$g^{\alpha\mu} \delta g_{\mu\nu} = -g_{\mu\nu} \delta g^{\alpha\mu} \,\, . $$ Multiply both sides by ##g_{\alpha\beta}## to get $$\delta g_{\beta\nu} = -g_{\alpha\beta} g_{\mu\nu} \delta g^{\alpha\mu} \qquad(*)$$ (This is Dirac's eq. (26.9) in "GTR".) On the other hand, the variation ##\delta g^{\alpha\mu} = \bar{g}^{\alpha\mu} - g^{\alpha\mu}## should be a tensor...
