Water Bottle: relationship between Volume and Time
22 replies · 17K views
srsthsr
To all who have given up their time to help. Could you please have a look at my experiment, I am really stuck with this and don't know how to go on with it. I am unable to find a suitable equation to prove it mathematically as there is a varying change in both time taken and the pressure inside the bottle, could anyone please give me a hint so I can get on with it
To investigate the relationship between the initial volume and the time it takes for the water to leak out of a hole beneath the bottle.
Variables:
Dependent Variable: Time it takes for all the water to flow out of the bottle
Independent Variable: Initial Volume of Water
Controlled Variable:Bottle and Gap size
Vol(ml)Time(s)
800 30.38
700 27.78
600 24.98
500 21.54
400 18.57
300 14.52
200 11.69
100 6.69
50 3.78
Experiment:(brief)
A certain volume of water is poured into a bottle with a blocked hole in the bottom.
unblock the hole and start the timer.
Measure the time it takes for the water to stop drippiing.
p = ρgh?
Thank you so much
welcome to pf!
hi srsthsr! welcome to pf! :smile:
(have a rho: ρ :wink:)
if A is the cross-section area of the bottle, and if V and h are the height and the volume of the water, and B is the cross-section area of the hole,
then V = Ah …
so what is dV/dt? :smile:
then V = Ah …
Thank you so much for the reply.
However, I think I am missing something out.
if V=Ah then dV/dt = Adh/dt + hdA/dt right? how does it relate to B which is the cross section area of the hole? I am missing something out
I found out that the height at Vol 800ml is 14.45 cm, the radius of the bottle is 4.77465, area cross section A is 225, and Area cross section B is 3.519...
hi srsthsr! :smile:
then dA/dt = 0, so it's just dV/dt = Adh/dt :wink:
it doesn't
dV/dt = Adh/dt is just geometry
now you need a physics equation relating dV/dt to h and B :smile:
(in english: how does the loss of water depend on the depth and on B?)
tiny-tim said:
hi srsthsr! :smile:
it doesn't
I am sooooooo sorry for the late reply
I still however don't get it, i mean the depth? and the size of the hole? I am really confused :cry: i can't seem to find out the equation anywhere! i don't even know where to start looking =[...
Thank you so much for helping me out!
okay... in English... the bigger the hole the more amount of water leaks out in a certain amount of time. The greater the depth, the more pressure, also the more amount of water leaking out...
I get it, but i can't find an equation to relate all of them together and prove that the numbers that i got from the experiment actually is correct (to an extent) =[
hi srsthsr! :smile:
right! :smile:
so you need two equations, one to tell you the https://www.physicsforums.com/library.php?do=view_item&itemid=80" , and one to tell how the pressure affects the speed
i] pressure = ρgh (ρ is density)
ii] https://www.physicsforums.com/library.php?do=view_item&itemid=115"
… the bigger the hole the more amount of water leaks out in a certain amount of time.
this is just geometry … if you know the speed, then just write out the definition of flow …
iii] flow = volume per time = area times distance per time = area times speed :wink:
Thank you for the rapid response, the problem is though, that the speed is not constant and varies as pressure and volume changes doesn't it?... how would I find the average speed?
i don't understand … why do you want to find the average speed? :confused:
all the question asked for was …
OK, I will give it a try, I think I've found out what you meant =P thank you! will reply soon =]
Okay I tried out your equation, but the constant from Bernoulli's equation keeps changing.
Could you please tell me what I did wrong?
1) Flow rate of 0.8L
(0.8e-3)/30.38=2.63e-5(m^3/s)
2)speedxarea(of hole)=volume/time
so speed=2.63e-5/0.0056x2x3.1416=7.484e-4
3) P=pgh=1x9.81x0.1445=1.417545
4)using Bernoulli's equation along any streamline of a steady incompressible non-viscous flow: constant=2.8351
5)Flow=Vol/t=speed x area
6)so speed=V/at
7)rearranging equation, 2(pgh)+(0.5(V/at)^2) should equal to 2.8351, but it doesn't for other values! i.e. Vol=0.7L and time=27.78, =[ please help
hi srsthsr! :smile:
no, your v in https://www.physicsforums.com/library.php?do=view_item&itemid=115" has to be the instantaneous velocity at time t …
your data …
… are giving you initial volume over total time,
which gives you an average velocity instead :redface:
then what should i do? I am so confused ;(
OKAY, will do that, i have a plotted graph already, however, isn't the relationship parabolic? or is it a straight line?
once i get dV/dT which is A(dh/dt) then do i divide the answer by A and then that would give me dh/dt or in english, rate of change of height per time... which is the instantaneous speed?
I hope i am not being too much of a trouble for you =[
Be back soon, looking forward to your reply =]
AHHHH, I am going crazy =/... ok L^3/T is the rate of flow... but we want velocity... so do i times it by 1/h? i don't know... and what does the gradient represent, i understand that its Adh/dt so what does Adh/dt mean? =[ this is confusing me so much i don't know what to do!
hi srsthsr! :smile:
it's really very logical :wink:
dV/dt = Adh/dt
ie flow rate = bottle area times bottle speed
similarly
flow rate = hole area times hole speed
ie dV/dt = Bv
so v = … ? :smile:
(btw, this is all geometry, not physics!)
(and next you put this v into Bernoulli's equation)
so r u saying that (dV/dt)/B is v? and i just put that into the equation and i get the constant?
also, is the P in Bernoulli's equation the same as pgh?
yes :smile:
Bernoulli will give you an equation in h, so you'll need v as a function of h, not of V, won't you? :wink:
