Using my experience on DIY Central Heating here is a hopefully not too comprehensive answer.
TSN79 said:
I'm thinking between 0.4-0.8 m/s as optimal. I'm worried that sound might become a problem with higher speeds? And also pressure loss...
Heating flow is not rated in velocity but volume flow rate as in a closed loop system velocity varies with aperture size and head if I remember by Benoullis equations right. In facyt if you look at heating pumps they have large apertures in order to reduce the required pumping velocity for a given bulk flow.
A quick squint at the Gundfos website (
http://www.grundfos.com/web/homeuk.nsf) gives a typical Central Heating flow rate of 1 l/sec on the flat reducing to about 1/4 l/sec at a head of 5m. A recommended (UK) system flows through a 22mm ring tapping off to 15mm tails at the radiators so in order to maintain. My house is a mixture of 3/4", 1/2", 22mm, 15mm and 8mm spread across 4 floors so the water velocity is up and down all over the place, but the bulk flow remains constant.
The Noise issue should not be affected by water velocity in an air free system (Using an auto-bleed at the top of the system with a make up valve is a good idea). What I found when I moved into my house though was that some of the thermostatic valves were the wrong way round, so as they closed against the flow they fluttered causing banging throughout the system. Check the arrows on the TGV's so they close with the flow.
Pressure loss is why plumbers recommend 22mm ring as it has a better volume/surface area ratio, but you then are pumping more water around that is not in the radiators which is why some people prefer 8mm or even 6mm. I've used it as it is really easy to run in tight spots.
To select your pump you need to check the boiler you are using as it will have a maximum pressure and flow rate that it is capable of getting up to temperature, and the maximum head in your system as you need to maintain the flow through the highest point in your system.
