Wavelength of the 2nd Overtone of a string.
  • Thread starter Thread starter MissKaylaPaige
    String Wavelength
The discussion revolves around finding the wavelength of the 2nd overtone of a string that is 4.5 m long, with a transverse speed of 48 m/s. Participants are exploring concepts related to wave properties, specifically harmonics and overtones.
  • Mixed
  • Participants are attempting to clarify the relationship between frequency and wavelength, particularly regarding the fundamental frequency and its corresponding overtone. There are questions about the definitions and calculations of frequency and wavelength, with some suggesting different interpretations of the overtone concept.
The discussion includes various interpretations of the overtone and its relationship to the fundamental frequency. Some participants have provided insights into the calculations, while others express confusion about the definitions and units involved. There is no explicit consensus on the correct approach or values.
There are conflicting statements regarding the fundamental frequency and wavelength, with some participants questioning the accuracy of the values provided. The discussion also touches on the distinction between overtones and harmonics, indicating a need for clarification on these concepts.
MissKaylaPaige
Find the wavelength of the 2nd overtone of a string 4.5 m long between points with a transverse speed of 48 m/s.
Since the fundamental frequency is 9, shouldn't the 2nd overtone be 2/3 of that? I'm completely baffled!
Please??
Ok, I'll try. Shouldn't the second overtone be three times the fundamental frequency? Furthermore, why should the fundamental frequency be '9'? Use units, please! Isn't the fundamental wavelength 9m? I think you are confusing wavelength and frequency.
I don't remember what an overtone is because it is worthless, all you care about are eigenfrequencies and harmonics, but I think she is right.
The first overtone, unless I am getting it confused with something else, would be if you were to divide the length of the string into half. The second would be if you were to divide it into 1/3, the fourth of 1/4, and then you want the node before the end. So for the second overtone 1-1/3 = 2/3. Of course then you would have to multiply that factor by the total wavelength.
Yes, I meant the fundamental WAVELENGTH is 9m. The fundamental FREQUENCY is 5.3 Hz. But no, 3 times the fundamental frequency is not giving me the correct answer for the wavelength of the 2nd overtone.
If the fundamental wavelength is 9m, then the second overtone is wavelength 3m. That has 3 times the frequency of the fundamental. Now you've got Mindscrape confused. The fundamental frequency isn't 5.3Hz, it's 16/3 Hz which is 5.33333333...Hz. I think you are making a rounding error.
Dick is correct. Wave speed = frequency * wavelength
48.0 m/s = freq * 9 m
freq= 48/9 = 5.33 Hz
I know this is a post 4 years later and you either figured this problem out or shot your professors dog. Either way, I am taking physics 3 now and i am looking up overtone as well :) and I am planning on shooting his dog :P
EDIT: I found out that MINDSCRAPER is correct, overtone is useless.
Overtone is related to harmonic by being 1 behind (aka. 2nd harmonic --> 1st overtone, 3rd harmonic --> 2nd overtone)
Therefore, 2nd overtone frequency = 3 * fundamental frequency
2nd overtone frequency = 3 * 9 m = 27 m
2nd overtone wavelength is found working backwards with the equation v = lambda * frequency
21K
18K
  • · Replies 17 ·
