Weak & Strong Magnet attract each other no matter what polarity
The discussion centers on the interaction between strong and weak magnets, specifically how a strong magnet can attract a weak permanent magnet (PM) or electromagnet regardless of polarity. When power is increased to the electromagnet, it can exhibit repulsion. The phenomenon is attributed to the realignment of magnetic domains in the weaker magnet due to the stronger magnet's field, which can temporarily reverse its polarity. The conversation also touches on the relative strengths of magnets needed for both attraction and repulsion, as well as the distinction between magnetically hard and soft magnets.
  • Understanding of magnetic domains and their behavior
  • Familiarity with electromagnet construction and materials, such as mild steel
  • Knowledge of permanent magnets and their properties
  • Basic principles of magnetism, including attraction and repulsion
  • Research "magnetic domain theory" to understand how magnetization occurs
  • Explore "electromagnet design" for optimal performance in attracting and repelling
  • Study "magnetically hard vs. soft magnets" to differentiate their applications
  • Investigate methods to "measure magnetic field strength" using multimeters and CROs
Engineers, physicists, and hobbyists interested in electromagnetism, magnet design, and applications involving magnetic attraction and repulsion.
sachooo
Recently while working with electromagnet , we noticed one thing.
I we bring strong magnet near very weak PM or electromagnet, It will attract the weak one whatever is the polarity of magnets.
we increased power to electromagnet then it was giving repulsion.
I did't understand this phenomenon can anybody explain this to me.
Welcome to the PF.
What are electromagnets constructed of? You wind wire around what kind of metal?
Welcome to the PF.
We used simple mild steel but we observed this behaviour with permanant magnets too.
A strong magnet will attract an ordinary piece of iron. In the case where the weak magnet is very weak, it behaves more like an ordinary piece of iron than a strong magnet.
To express this in more detail I think(but do not know enough about domain theory to be sure)that the field of the stronger magnet temporarily realigns the domains of the weaker magnet such that attraction always occurs.As an example if the N pole of the stronger magnet were brought close to the N pole of the weaker magnet then the domains of the weaker magnet would be flipped round such that its poles reverse.Perhaps if contact was maintained for a long enough time the polarity reversal of the weaker magnet would become permanent.What happens must also depend upon the types of magnets used as well as their strengths.
Thanks You all for this information.
In our project We are trying to attract & repel permanant magnet. To get max force we tried use high power permanant magnet & so we had this problem.
But now I would like know what should be relative strength of both magnets sothat there will be attraction & repulsion both.
Is there any document or book dealing this issue.
Is there any method to measure field strength with multimeter CRO. ( normal electronics Lab instruments )
Hello sachooo.It is relevant to know the difference between "magnetically hard" and "magnetically soft" magnets.I think the Wiki article entitled "magnet" contains all of the information you need and more.
  • · Replies 22 ·
  • · Replies 27 ·
18K
