Weight percent and concentration problem
4 replies · 9K views
shiyao85
the question is at below.
320ml of 29wt% of ammonium hydroxide
1210ml of 31wt% of hydrogen peroxide
30190ml of water
mixed together.
What is the concentration of ammonium hydroxide and hydrogen peroxide now?
Is there any reaction occurs between them?
Conversion of weight percent to molarity
*Cw=(10×Mw×M)/ρ
Where Cw is weight percent
Mw is molar mass
M is molarity
ρ is density of the solution
Assumption: -No reaction between ammonium hydroxide and hydrogen peroxide
-Hydrogen peroxide
Density = 1.44g/mL
Cw = 31wt%
Mw = 34g/mol
From *
M1=0.131mol/L
V1 = 1210ml = 1.21L
-Ammonium hydroxide
Density = 0.9g/mL
Cw = 29wt%
Mw = 35g/mol
From *
M2 = 0.0745mol/L
V2 = 320ml = 0.32L
After mixing:
Total volume of the solution is 31.72L.
Formula for dilution
MiVi = MfVf
For ammonium peroxide
MiVi = MfVf
(0.0745mol/L) X 0.32L = Mf X 31.72L
Final molarity of NH4OH in the solution is 7.51X10^-4 mol/L.
For hydrogen peroxide,
MiVi = MfVf
(0.131mol/L) X 1.21L = Mf X 31.72L
Final molarity of H2O2 in the solution is 5X10^-3 mol/L.
Remarks:
*http://www.chembuddy.com/?left=concentration&right=percentage-to-molarity
Density of the substances from internet
http://actrav.itcilo.org/actrav-english/telearn/osh/ic/1336216.htm
http://en.wikipedia.org/wiki/Hydrogen_peroxide
I was stuck in the part of final volume. Not sure one which the number i should use. Is it total volume of the solution? or just the volume of the chemical and water?
OPs..
Sum masses of all solutions and assume density to be that of pure water (mass is conserved after all, which can't be said about volume). You won't find anything better and the final solution seems to be quite diluted.
ChemBuddy chemical calculators - buffer calculator, stoichiometry calculator
www.ph-meter.info - ph meter, ph electrode
So have to convert the total volume to mass rite? assume the density to be 1 for all the solute also rite? because all of them are quite dilute..
