What Angle Causes Particles A and B to Collide?
3 replies · 4K views · last reply
BeyondBelief96
A particle A moves along the line y = d (30 m) with a constant velocity
(v= 3.0 m/s) directed parallel to the positive x-axis (Fig. 4-40). A second particle B starts at the origin with zero speed and constant acceleration
(a = 0.40 m/s2) at the same instant that particle A passes the y axis. What angle θ between
and the positive y-axis would result in a collision between these two particles?[/B]
Kinematic Equations
So I listed out all knowns and unknowns for both particle A & B as follows:
Particle A: Xi = 0, Xf = ?, Vix = 3 m/s, Vif = 3m/s, a = 0 t = ? and y = 30
Particle B: Xi = 0, Xf = ?, Vix = 0 m/s, Vif = ?, ax = asin(theta), t = ?
Yi = 0, Yf = 30, Viy = 0 m/s, Vif = ?, ay = acos(theta), t = ?
From there I used the kinematic equation d = vit + 1/2at^2 for particle A and B and got the following:
Particle A: x = 3t, y =30
Particle B: x = 1/2asin(theta)t^2, y = 1/2acos(theta)t^2
I set each of the equations equal to each other and tried to solve the system of equations for theta as follows:
3t = 1/2asin(theta)t^2 (Eq1)
30 = 1/2acos(theta)t^2 (Eq2)
3 = 1/2asin(theta)t so t = 6/asin(theta)
So I plugged t into Eq2:
30 = 1/2acos(theta)[6/asin(theta)]^2
from here I am at a loss on how to solve for theta. To be honest, my algebra solving skills arent super spectacular, which is a bit sad haha. I was able to simplify this as:
30 = 1/2acos(theta)[36/a^2sin^2(theta)] == 5/3 = cot(theta)/asin(theta) ...aaaaaand this is where I am lost.
[/B]
  • Diagram of two particles in the xy-plane: particle A at height d on the y-axis moving right with velocity v, and particle B at the origin with acceleration a at angle theta from the positive y-axis.
BrandonBerisford said:
A particle A moves along the line y = d (30 m) with a constant velocity View attachment 229683 (v= 3.0 m/s) directed parallel to the positive x-axis (Fig. 4-40). A second particle B starts at the origin with zero speed and constant acceleration View attachment 229681 (a = 0.40 m/s2) at the same instant that particle A passes the y axis. What angle θ between View attachment 229682 and the positive y-axis would result in a collision between these two particles?[/B]
Kinematic Equations
[/B]
Here is a technique that you can use on a lot problems like this to eliminate angle ##\theta##.
##3t = \frac 1 2 a\,t^2 \sin(\theta)##
##30 = \frac 1 2 a\,t^2 \cos(\theta)##
##9t ^2= \frac 1 4 a^2t^4 \sin^2(\theta)##
##900 = \frac 1 4 a^2t^4 \cos^2(\theta)##
_____________________
##9t ^2 + 900 = \frac 1 4 a^2t^4##
In the last step, I just added the two equations. Now you have a quadratic equation to solve for ##t^2##.
NEW
oh okay, that makes sense! So once I've solved for t^2 just square root it for t, and then plug it into one of my original equations then solve for theta?
NEW
Right.
