What are auxiliary quantities and function linearization in physics?
  • Thread starter Voidness
    Exam Study
27 replies · 3K views · last reply
Voidness
Hello guys,
Tomorrow Ive got exam. Ive studied well but I dont understand everything, I would appreciate if someone could help me about auxiliary quantity and linearization of a function in physics.
I dont speak English well.
Hello and :welcome:!
You're a bit late, are you?
I'm not sure I know what exactly you mean by auxiliary quantity. The Planck constant has been regarded as such when it first was introduced in 1901, but that's possibly a more historical aspect. The absolute magnitude in astronomy is an auxiliary quantity. I would consider them as quantities that occur in solution processes although they are not the primary goal of an experiment or a calculation. This is very general and an exact definition might be impossible as it depends on the context.
Linearization of a function is probably the local (!) approximation of a function by its first derivative. If you consider the Taylor series of a function ##f(x)## at a point ##a## then its Taylor series is
$$f(x)=f(a)+f'(a)\cdot (x-a) + f''(a)\cdot \dfrac{(x-a)^2}{2}+f'''(a)\cdot \dfrac{(x-a)^3}{3!}+\ldots $$
and a linear approximation in a neighborhood of ##x=a## is thus ##f(x)\approx f(a)+f'(a)\cdot (x-a).##
Another form of a linearization (in mathematics) is the approximation of ##f(x)## by a chain of straights, i.e. a chain of piecewise linear functions along the graph of ##f(x).## However, in physics, it is probably the Taylor series.
Here is an article on some things that should be considered in an exam:
https://www.physicsforums.com/insights/10-math-tips-save-time-avoid-mistakes/
These are all very general considerations. It may help if you had more specific questions and examples.
Hello,
Thank you for your reply. I am not late, I can almost do everything but there are some things I dont understand. I am beginner to physics and I think what you have written there is not for beginners. I also think that there is an misunderstanding because lack of my language. I am sorry of my deficit of my English.
Textbook page showing a graph of x in m against t² in s², with a straight line through the origin rising to about 1.19 m at t² = 5.00 s², labelled Bild 2: Linearisierung gemäß Tabelle 1, with the formulas k = Δx/Δ(t²) = 0,238 m/s² and a = 2·k = 0,48 m/s².
Textbook page showing a linearization graph: x in m against t squared in s squared, a straight line through the origin rising to about 1.20 m at 5.00 s squared, with a shaded triangle beneath it, labelled Figure 2: Linearization according to Table 1.
Voidness said:
Hello,
After some time of studying I could understand some of it but not the whole thing.
Your example was ##x=\dfrac{1}{2}a\cdot t^2.## This means that ##x\sim t^2## is proportional to ##t^2.## If we forget that ##t^2## is time squared and call it ##H## then ##x \sim H## is proportional to ##H## which is an auxiliary quantity (Hilfsgröße) which we only need to draw the ##(x,H)##-diagram. Although ##x## is a quadratic function of ##t##, it is also a linear function in the new variable ##H=t^2.## That changes the diagram ##\left(x=\dfrac{a}{2}t^2, t\right)## which is a parabola into a diagram ##\left(x=\dfrac{a}{2}\cdot H, H\right)## which is now a linear line - that's why it is called linearization in this context.
What we did was change the scale of the horizontal axis from ##t## in seconds into ##H## in seconds squared. We "linearized" the diagram by introducing ##H.## It's mainly just words that should describe the change in our perspective.
You should read the article I linked to. It definitely contains helpful tips for your exam. I wrote it from my experiences of tutoring kids at school.
So it changed quadratic formula to linear formula, so we could calculate it easier. Why does it change to linear when we do t^2 = H, I know how to calculate quadratic- and linear functions but whats the theory behind it. I also got some exercises about this, could you help me with it please?
Ok, thank you for the article.
We only look at it differently.
There is no theory behind it. We use different scales all the time. Distances in space are measured in lightyears. However, you would have problems measuring your way to school in lightyears. Meters and kilometers are better suited.
It is a change of perspective: ##x=t^2## is a quadratic parabola, ##x=H## is a straight. It is a different point of view, not a different physical process.
It is only a change of perspective. Another example is the scale of earthquakes. It is a logarithmic scale and basically says that M5 is 10 times rougher than M4, and 100 times rougher than M3.
"How to calculate" depends on what quantities you have been given. I assume that we measured time, so we have been given values of ##t.## Then ##H=t^2## but we did not measure ##H.## That's why it is called auxiliary - we can calculate it as ##H=t\cdot t,## but we do not measure it.
Ok, thank you. I was able to calculate the exercise with your help. I have one more question what is darkening time?
  • Handwritten work: a table of h (cm) against t (ms) with values 70/378, 60/352, 50/321, 40/288, 30/249, 20/205; below it y(t) = 1/2 g t^2, x = k t^2, k = x/t^2, k = 70/378^2 = 4.89 x 10^-4, k = 1/2 g, g = k 2, g = 9.79 x 10^-4 cm/ms^2.
  • Scanned German textbook page titled 4.4 Aufgaben zum freien Fall with two experiment photos and two data tables: Tabelle 1 of fall time t against fall height h, and Tabelle 2 of darkening time Δt against fall height h for a 40 mm ball.
  • Textbook page on free fall: a drop device photo with a stand and clamps, Table 1 of fall time t against fall height h (70 cm 378 ms down to 20 cm 205 ms), a light barrier apparatus with a timer unit, and Table 2 of darkening time Δt against fall height h for a 40 mm sphere (60 cm 10.73 ms down to 20 cm 19.24 ms).
It's also only a word and a bit of "eine unglückliche Bezeichnung".
I assume that an object falls through a photoelectric sensor (Lichtschranke) and the moment it does so darkens the sensor (verdunkelt den Sensor). They have called it darkening time (Verdunklungszeit). It is the moment in time the sensor gets dark and measures the time, or maybe the time span during which the sensor is dark.
Nothing specific about it.
Ok, thank you. It looks like I am stuck again. I dont know how to continue with the exercise 2a). I only got this. Could you help me please.
Handwritten notes for a falling-body experiment: a table of h in cm against Δt in ms (60 cm, 10.73; 50, 11.50; 40, 13.36; 30, 16.09; 20, 19.24), equations y(x) = ½·g·t² linearized to y = k·t² with k = ½g, a sketch of a vertical scale marked 0, 50 and 60 with a block and d = 40 mm, and 2x/t² = g with g underlined.
I think that I got it finally
  • Handwritten physics working on a whiteboard: a table of h in cm against Δt in ms, equations y(x)=½gt² and v²=2gh, a sketch of a vertical drop with d=40 mm, and a linearization giving k=0.23 and g=0.11.
Let me think out loud to get the problem. We measure a timespan ##\Delta t## during which the steel ball falls with a constant acceleration ##g## through the sensor of sensor length ##d.## The timespan depends on the height ##h_0## of the fall, which is the only variable quantity resulting in varying velocities. It also means that the steel ball enters the sensor at different velocities.
My problem is now that my method differs from your method in the book and I have only limited access to the book. My equations get a bit complicated as I consider time as my central variable and not height.
If ##t_2## is the total timespan of the fall from height ##h_0## and ##t_1## the timespan of the fall until it enters the sensor, then ##h_0=\dfrac{1}{2}g\cdot t_2^2## and ##h_0-d=\dfrac{1}{2}g\cdot t_1^2## where ##d=40\, \mathrm{mm}## is the length of the sensor and we measure ## \Delta t= t_2-t_1.## Then
\begin{align*}
d&=h_0-(h_0-d)=\dfrac{1}{2}g\cdot t_2^2 -\left(\dfrac{1}{2}g\cdot t_1^2\right)\\
&=\dfrac{1}{2}g\cdot (t_1+\Delta t)^2 -\left(\dfrac{1}{2}g\cdot t_1^2\right)\\
&=g\cdot t_1\cdot\Delta t +\dfrac{1}{2}g\cdot \left(\Delta t\right)^2\\
&=\underbrace{\sqrt{2g\cdot (h_0-d)}}_{=v_0}\cdot \Delta t+ \dfrac{1}{2}g\cdot\left(\Delta t\right)^2\\
\end{align*}
where ##v_0## is the velocity of the ball when entering the sensor.
I need to find a suitable coordinate system, i.e. when time starts ticking: with the fall (as in my equations), or when entering the sensor, and a suitable way to describe the different velocities when the ball enters the sensor in dependence of height. This velocity is proportional to the time of the fall before and proportional to the square root of the height. I have to figure out how this is dealt with in your book without having the book. This velocity is crucial since it directly affects how long the ball takes to pass the sensor.
It would be easier if we only had falling time and height but the book mentions the "Verdunklungsdauer" as its variable.
\begin{align*}
\end{align*}
d is the diameter of the sphere. Sorry for the misunderstanding.
This makes no difference and does not solve the problem with the initial velocity when the ball arrives at the sensor. Let's see.
We basically have ##d = v(h) \cdot \Delta t + \dfrac{g}{2} \left(\Delta t\right)^2## where ##\Delta t## is the dark time and ##v(h)## the velocity when entering the sensor, dependent of the height ##h## between starting point and sensor. The ball needs ##d/v(h)## seconds to pass the sensor without additional acceleration. With additional acceleration, we have to solve ##d = v(h) \cdot \Delta t + \dfrac{g}{2} \left(\Delta t\right)^2## where we have measured ##\Delta t ## and know ##d##. We have one equation with two unknowns ##g## and ##v(h).##
I love physics but sometimes I wonder if I am too dumb for it :rolleyes:
Cant even do beginners physics. I need to invest more time with physics.
I think the velocity is ##v(h)=g\cdot h##. Since we know ##h## we can calculate ##v(h)## and solve the equation. I simply do not see where "linearization" kicks in as we get
d=g\cdot h \cdot \Delta t + \dfrac{g}{2}\cdot \left(\Delta t\right)^2.
Correction: ##v(h)=\sqrt{2\cdot g\cdot h}## and ##d=\sqrt{2\cdot g\cdot h} \cdot \Delta t + \dfrac{g}{2}\cdot \left(\Delta t\right)^2.##
Proof: Velocity is ##v(h)=g\cdot t## and height is ##h=\dfrac{1}{2}g\cdot t^2.## Eliminating ##t## as the time of the fall results in ##v(h)= g\cdot \sqrt{\dfrac{2h}{g}}=\sqrt{2\cdot g \cdot h}.##
I dont see it either but it says, that I have to determine the fall acceleration with linearization. I will just skip this and continue with other themes. Next time will spend more time.
I am very thankful for your help, Sir.
I made a mistake. The velocity is ##v(h)=\sqrt{2\cdot g\cdot h}.## It falls on a length of ##h## at an acceleration ##g##. Hence my formula should have been
d=\sqrt{2\cdot g\cdot h}\cdot \Delta t +\dfrac{g}{2}\left(\Delta t\right)^2.
The point is: the higher it falls the faster it is when it arrives at the sensor. Then it is also accelerated further when passing the sensor.
My suspicion is that we consider the quadratic term as too small to influence the result so that we have
d=\sqrt{2\cdot g\cdot h}\cdot \Delta t +\dfrac{g}{2}\left(\Delta t\right)^2\approx \sqrt{2\cdot g\cdot h}\cdot \Delta t
and that this is the linearization. This means
g\approx \dfrac{d^2}{2h} \cdot \dfrac{1}{\left(\Delta t\right)^2}
or
\left(\Delta t\right)^2 \approx \dfrac{d^2}{2h}\cdot \dfrac{1}{g}
I have a question but this is a little personal. Next year I will have to go to uni but I havent chosen which degree. I have in my mind physics, math, chemistry, machine engineer or something with radiation. You prob. have much more experience than me. How did you chose which degree you wanted to study?
You're too fast for me. I type directly here and make mistakes which I have to edit. Please refresh the page and see my edits.
These are very different fields. They differ in my opinion mainly in the languages they use.
Mathematicians and physicists both write in mathematical formulas. However, mathematicians concentrate on the object, and physicists on the coordinate systems. That makes a huge difference in the sense that different notations become important. I am a mathematician and a Lie algebra is an algebraic object to me, a vector space with a certain multiplication. To a physicist, a Lie algebra is generated by the flows of a particle through a vector field. It is the same thing but viewed at very differently.
Chemistry needs a lot more things to learn by heart. It is full of facts that you cannot derive from something. You have to learn facts.
Engineering has a lot to do with actual calculations, full of formulas and explicit numbers.
Not sure what you mean by something with radiation. That can go from nuclear engineering, in which case I hope you are from Switzerland since Germany has quit running nuclear power plants, medical applications, or high-energy physics.
So which of the above descriptions match your strengths?
I am from Germany :cry:. I cant chose, I love four of them but also know that I cant learn everything. I even do internship in a Uni but still cant chose. Mostly math, physics and machine engineer. I can do math well and have even joined to math races when I was little. But with physics you can see the secrets of the universe and with the machine engineer you can build your own things which I love. Chemistry is also very cool, you can do many thing with the elements.
As I said. They require different strengths. You could figure out what is taught in the first or first two semesters in the different fields. Then search for them with the appendix "+pdf". E.g., search for
  • <Analysis I + pdf> or <calculus I + pdf>
  • <klassische Mechanik + pdf> or <classical mechanics + pdf>
  • <mathematik für ingenieure + pdf> or <mathematics for engineers + pdf>
  • <organische Chemie + pdf> or <organic chemistry + pdf>
  • <Kern und Teilchen Physik + pdf> or <nuclear physics + pdf>
then select a university site where you will usually find a lecture note. Sometimes you can also find a textbook. In any case, look at those and see which of them appears easy to learn for you.
Thank you for your help, Sir. May I contact you in the future?
Sure, PF is a good place to come for all of these fields.
Ok, have a good night. I will prob. continue to study till very late.
