What are the drawbacks of free piston engines and how can they be improved?
  • Thread starter Thread starter Stanley514
    Engine Piston
Free piston engines face several drawbacks, including oil consumption, noise from short explosions, and lower efficiency compared to four-stroke engines. Strategies to reuse oil, akin to four-stroke systems, are being explored to address oil burning issues. The noise generated by free piston engines is a concern, with challenges in effective muffling due to the nature of the explosions. Additionally, two-stroke free piston engines may suffer from incomplete fuel combustion, leading to reduced efficiency compared to their four-stroke counterparts. Overall, advancements in technology and design are needed to improve the performance and practicality of free piston engines.
Stanley514
There are following problems associated with free piston engines (generators).
Do you know if there exist some ways to overcome it?
1)Free piston engine burns oil.What could be done to reuse oil similar to four-stroke engine?
2)Free piston engine produces very short explosions which are claimed very difficult to muffle.
How noisy it really is?As I know ``muffler`` works good even with pistol though pistol produces even shorter explosions.
3)Two stroke free piston engines are claimed to be less efficient than four stroke engines
because they are two stroke.Due to short cycle fuel burns incompletely etc.
Is it really so?And how much do they loose in efficiency?
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
