What Causes Induced EMF in Moving Conductors and Transformers?
The discussion centers on the causes of induced electromotive force (EMF) in moving conductors and transformers, specifically addressing the interaction of magnetic fields with electrons. Participants clarify that Lorentz's force, defined by F=q(VxB), acts on charges moving relative to a magnetic field, leading to induced EMF. The conversation emphasizes that while electrons may align their spins in a magnetic field, they do not generate a magnetic field unless they are in motion as a current. Faraday's law of electromagnetic induction is cited as the principle behind EMF generation in transformers due to changing magnetic flux.
  • Understanding of Lorentz's force and its formula F=q(VxB)
  • Familiarity with Faraday's law of electromagnetic induction
  • Knowledge of magnetic fields and their interactions with charged particles
  • Basic concepts of electron behavior in conductive materials
  • Study the principles of Faraday's law of electromagnetic induction in detail
  • Explore the concept of Lorentz force and its applications in electromagnetism
  • Investigate the behavior of electrons in conductive materials, focusing on thermal motion and induced currents
  • Learn about the cyclotron resonance in metals and its implications for measuring effective mass
Physics students, electrical engineers, and anyone interested in understanding the principles of electromagnetism and the operation of transformers.
brian.green
I read many different explanation but none of them is satisfying.
There is two cases:
1. I move an iron rod in a magnetic field, between two bar magnet for example.
To this case I read that when I move the rod the electrons on it also move and moving charges produce magnetic field which interact with the external B field. I think this is impossible because those electrons don't move locally just relatively. This cannot produce net magnetic field arround the rod just allign the spin of the electrons. Maybe this B field interact with the external one?
2. Iron core of a transformer transfer the energy.
In this case electrons in the secondary winding don't move at all. Allign to the external B field but just due to its spin magnetic moment. Just the spin allign and e- doesn't move at all. What causes the charge separation?
Lorentz's force acts on the charges when they are moving relative to a magnetic field with some velocity V.
F=q(VxB)..
brian.green said:
2. Iron core of a trafo transfer the energy.
What's "trafo"? Do you mean a transformer? If yes, I still don't understand your question.
F=q(VxB)..
B field can interact only with B field. Where is the B field of those "moving" electrons? The spin magnetic moment interact here? (Because at the Lorentz force two B field interact each other.)
Yes, transformer. What cause the EMF in the secondary coil? The changing magnetic field just allign the spin of the electrons. Why they move?
"B-fields" do not interact with each other.
Magnetic fields interact with moving charges.
Read this:
http://www.school-for-champions.com/science/magnetism_lorentz.htm
"Cause of Lorentz Force
A magnetic field is created by the motion of an electrically charged particle—such as a proton or electron. If that electrical charge is moving through an external magnetic field, there will be a magnetic attraction or repulsion force, depending on how the two magnetic fields interact."
But when you move a rod, electrons and protons both move in the same direction with same velocity. Therefore, the rod can't generate a magnetic field of its own.
When only the electrons are moving, i.e. when a current is flowing, a magnetic field is set up.
According to Faraday's law of EM induction, emf is induced in the secondary because there is a changing magnetic flux through the secondary winding.
There is two cases:
You are introducing an artificial (or maybe meaningless) distinction here. A charge moving in a magnetic field experiences the Lorentz force. It does not matter how did it get to move. In a metal even the thermal motion of the free electrons results in a magnetic force that curves their trajectories. See "cyclotron resonance in metals" (can be used to measure the effective mass). When the bar has an overall translation, there is an extra effect on top of this, which we measure as an overall emf.
An by the way, is there any other way to move than relatively (to something)?
The spins of the electrons have nothing to do with this.
  • · Replies 20 ·
