binis
- Messages
- 101
- Reaction score
- 8
- TL;DR
- Mpemba effect conditions
What are the conditions needed to occur the effect?
The answer to that isn't clear. It isn't clear whether there are any conditions that would reliably enable the effect to occur. And it is certainly only possible if one of the parameters of the experiment you might expect to be constant actually isn't. My best speculation is you might be able to cause it to occur if you have a large surface area to volume ratio in a low humidity environment, which causes a significant fraction of the hot water to evaporate, enabling the remaining water to cool and freeze faster than if the full amount were present.binis said:What are the conditions needed to occur the effect?
binis said:Summary:: Mpemba effect conditions
Really? I was looked for before post but failed.Could you please show me some?ZapperZ said:This forum has had a large number of threads on this topic
I agree.According to Newton's law of cooling, if we set as surrounding temperature To=0 => ΔT=T-To=T, during the cooling of a material body the rate of temperature decrease (cooling rate=q) is proportional to the temperature (T): dQ=mcdT= κAΔΤdt = κATdt => dT/dt=hT=qruss_watters said:The answer to that isn't clear. It isn't clear whether there are any conditions that would reliably enable the effect to occur. And it is certainly only possible if one of the parameters of the experiment you might expect to be constant actually isn't.
No.Since I got tired of reading other's articles in these threads,I think it is legitimate.Borek said:So you have come here pretending you ask questions, while in fact you are trying to promote your work?
Sneaky and rude if you ask me.
This is a peer reviewed journal member of DOAJ.Also,my perspective is accepted by Prof.Martin Chaplin.I can provide the link,if you permitt.Vanadium 50 said:The paper is in a predatory or near-predatory journal, and it shows a complete ignorance of thermodynamics. It asks us to consider two otherwise identical containers of water at the same temperature and different entropy. Obviously nonsense.
binis said:This is a peer reviewed journal
