What do sin, cos, and tan mean in trigonometry?
  • Level: High School
  • Thread starter John Dalton
    Cos Sin Tan
23 replies · 13K views · last reply
John Dalton
I am eager to learn trigonometry.
I have to be introduced to terms such as-sin,cos,tan,cosec etc.
The internet"s explanation is going over my head.
Can someone make them understand to me individually with the meaning of titha.(I cannot show its symbol , as it is not on the keyboard.)
I will grateful to all of them who will help me.
If you begin with a certain angle ## \theta ##, you can construct a right triangle (90 degrees for the second angle.) The cosine, ## cos(\theta) ##, is the ratio of one side (that goes to the 90 degree point) to the hypotenuse. (The longest side of the triangle=opposite the 90 degree angle.) The sine, ## sin(\theta) ## is the ratio of the side opposite ## \theta ## to the hypotenuse. Knowing the cosine and sine of angles allows for many measurements and calculations on various triangles. The law of sines, ## \frac{sin(a)}{A}=\frac{sin(b)}{B} ## and law of cosines, ## C^2=A^2+B^2-2AB \, cos(c) ## are also very useful in these calculations. (Note: The law of sines and cosines both apply to any type of triangle and not simply to right triangles.)
Theta is an intimidating word, but all it really represents is an angle in a given triangle. Sin, cos, and tan are measures of relationships in a triangle with the angle theta.
Right triangle with the right angle at bottom right; hypotenuse labelled c, vertical side a, horizontal base b, and angle theta at the bottom left vertex.
Let this be the triangle we're working with, with theta marked. The hypotenuse is the longest side, in this case marked "C". Sin(theta) is defined as the opposite side (to theta) over hypoteneuse, which in this case would be a/c. Cos is defined as adjacent side over hypoteneuse, or b/c. Tangent is opposite over adjacent, so a/b. Cosec, sec, and cotan are defined as the reciprocal of sin, cos, and tan respectively. You can see that using the fact of pythagoreans theorem, you can use it to prove that sin^2(theta)+cos^2(theta)=1, and this will lead to many other identities you can find. Trig is full of lots of little identities like this, I suggest you try and find more
Charles Link,Tyler6,rosekidcute:
Appreciate all the guidance you have provided me.I was not first initially understanding relation between the theetha and that of Sin,cos,tan .
Now I understood it is an angular unit and is associated with the hypotenuse of the triangle.
I specifically admire "Charles link" for he made me understood these things with utmost ease.
Thanks to all.
Superb,informative and precise explanation
In trigonometry, "sin," "cos," and "tan" are abbreviations for the following trigonometric functions:
  1. Sine (sin): The sine function, denoted as "sin," relates the ratio of the length of the side opposite an angle to the length of the hypotenuse in a right triangle. In other words, for a given angle in a right triangle, the sine of that angle is equal to the length of the side opposite the angle divided by the length of the hypotenuse.
    Mathematically, if θ is an angle in a right triangle:\sin(\theta) = \frac{{\text{opposite side}}}{{\text{hypotenuse}}
  2. Cosine (cos): The cosine function, denoted as "cos," relates the ratio of the length of the side adjacent to an angle to the length of the hypotenuse in a right triangle. For a given angle in a right triangle, the cosine of that angle is equal to the length of the side adjacent to the angle divided by the length of the hypotenuse.
    Mathematically, if θ is an angle in a right triangle:\cos(\theta) = \frac{{\text{adjacent side}}}{{\text{hypotenuse}}
  3. Tangent (tan): The tangent function, denoted as "tan," relates the ratio of the length of the side opposite an angle to the length of the side adjacent to the angle in a right triangle. For a given angle in a right triangle, the tangent of that angle is equal to the length of the side opposite the angle divided by the length of the side adjacent to the angle.
    Mathematically, if θ is an angle in a right triangle:\tan(\theta) = \frac{{\text{opposite side}}}{{\text{adjacent side}}
These trigonometric functions are fundamental in trigonometry and have many applications in mathematics, science, engineering, and various fields where angles and periodic phenomena are studied. They are commonly used to solve problems involving triangles, waves, and oscillatory motion, among other applications.
I think you mean ##\theta##, the lower-case Greek letter "theta". Even though it's not on my keyboard, either, I can use LaTeX to get it, like this: ##\theta##. In addition, many Greek letters are also avaiable as symbols under the ##\Sigma## menu along the top of the text input window.
For historical reasons, Greek letters are used in trigonometry, primarily ##\theta##, ##\alpha##, and ##\beta## (theta, alpha, and beta).
Mark44 said:
I think you mean θθ\theta, the lower-case Greek letter "theta". Even though it's not on my keyboard, either, I can use LaTeX to get it, like this: ##\theta##. In addition, many Greek letters are also avaiable as symbols under the ΣΣ\Sigma menu along the top of the text input window.
Thanks Mark for this helpful fact,I hope I will use them in my posts from the very next time.☺
Appreciate it!
No problem john dalton , because some time ago i have been searching for a book with everything trigonometry in it too
Reference sheet titled TRIGONOMETRY LAWS AND IDENTITIES listing tangent, reciprocal, Pythagorean, periodic, even/odd, double angle, half angle, product-to-sum, sum-to-product, sum/difference, Mollweide's, law of cosines, law of sines, law of tangents and cofunction identities, with EEWeb.com branding.
hope this helps too :)
Some folks use the mnemonic "sohcahtoa" meaning "sine = opposite/hypotenuse, cosine=adjacent/hypotenuse, tangent = opposite/adjacent"
You can memorize sohcahtoa or other tricks that people use to get through the next trig test. However, if you ever actually want to use trig, you need to understand the relationships that sine and cosine values have with as you travel along their domain.
One thing that always confused me when learning trig was that the teachers always described it as being all about triangles. And then they presented me with the unit circle and told me that it was also about trig. Then they showed me sine and cosine waves and said "this is trig too". There was no continuity in the way that trig was taught to me, until I was taught by an electrical engineer, who helped me see that sine and cosine are circular functions, just looking at the point on the circle from a different angle (90 degrees apart).
Watch this video :
Watch this video as well
This one goes more in-depth
This video is rather comprehensive
It is unfortunate today that we have long ago abandoned the teaching of Euclid. The quantity that we now call cosine first appeared in a real sense, but without the name, in the propositions 12 and 13 of Book 2 of Euclid, as generalizations of the Pythagorean theorem. These generalizations are known today as the law of cosines. Namely in a triangle with sides of length A,B,C opposite the angles a,b,c respectively, we have the formula C^2 = A^2 +B^2 -2ABcos(c). The case where c is a right angle and cos(c) = 0 is Pythagoras. In particular angle c is the angle whose sides are A and B.
In Euclid's statement he gives the quantity ABcos(c) as the area of a rectangle whose sides are A and the segment of length x along A obtained by dropping a perpendicular from the end of the side B away from angle c. Referring to the right angle formed by this perpendicular, and by B, and by the segment x cut from A by the perpendicular, by the triangle definition of cosine we have cos(c) = x/B, or x = Bcos(c). Thus the cosine function is a name for the function whose value determines the length of the projection of one side of an angle onto the other side of that angle. (I hope I have corrected my misprints.) (The length of the perpendicular itself is Bsin(c).)
As for the interpretation using circles, Euclid's whole approach to geometry is to use triangles to study circles and vice versa. In cartesian coordinates, the length of the two projections of an angle inscribed in the arc t of the unit circle, onto the two axes, are called cos(t) and sin(t) respectively.
This is my favorite point of view, and the original one. I hope this helps someone.
Surprised no one has addressed the trig functions for angles > 90 degrees. In high school we were just given their definitions without, as I recall, any particular concomitant rationale. I never bothered to figure them out back then & I still haven't!
@RogueOne posted several videos of trig functions and the unit circle, where the angle/argument is not limited to just acute angles.
I can't say for sure, since it has been really a long time since I was in high school, but I think we learned the trig functions as defined in the unit circle, not just for angles in a right triangle.
How does the "unit circle" provide the rationale for saying sin 100 = sin 80? Why is sin 80 = sin (180 - 80)?
You can't say "sine = opposite over hypotenuse" when the angle exceeds 90 deg!
Etc.
QUOTE="rude man, post: 5782708, member: 350494"]How does the "unit circle" provide the rationale for saying sin 100 = sin 80? Why is sin 80 = sin (180 - 80)?
[/QUOTE]Your two equations sin(100°) = sin(80°) and sin(80°) = sin(180° - 80°) are saying exactly the same thing, since 180° - 80° = 100°.
As to why sin(100°) = sin(80°), the cosine and sine of an angle are defined as, respectively, the x and y coordinates on the unit circle for an angle θ[ whose initial side is along the positive x-axis, and whose terminal side extends from the center of the circle to unit circle. (x, y) = (cos θ, sin θ) are the coordinates of the point on the terminal side that intersects the unit circle.
The angle 100° has a terminal side in the second quadrant. If you drop a vertical line segment down to the x-axis, you get the reference triangle (a right triangle) as shown in my drawing here.
Unit circle with x and y axes; a radius from the origin reaches the upper-left arc, with a right triangle dropped to the x-axis. The angle at the origin is labelled 80 and the angle from the positive x-axis is labelled 100.
The acute angle at the origin for this reference triangle is 80°. By symmetry it's easy to see that the triangle I've drawn in the second quadrant can be flipped across the y-axis to get a right triangle in the first quadrant. Clearly sin(80°) is equal to sin(100°) by this symmetry - both triangles have exactly the same altitude, and both have the same hypotenuse (= 1 unit).
It shouldn't be too much of a stretch to see that the magnitudes of the bases of the two triangles are the same, but opposite in sign, so cos(100°) = - cos(80°).
in post #14 i referred to the law of cosines proved in props 12 and 13 of book 2 of euclid. the reason there are two propositions for one law is that they viewed positive and negative numbers as two separate cases then. i.e. when the angle is > 90degress, cos is negative, and when the angle is < 90degrees the cosine is positive. i recommend taking a look at euclid. your question is also interesting in regard to the proof that the two parallelograms on the same base and with the same height can be decomposed into each other. it is much harder when the vertices of the second triangle are both outside the first parallelogram. see page 14, (day 6):
http://alpha.math.uga.edu/~roy/camp2011/10.pdf
To allay all faras: I assuredly did learn how to interpret sines and cosines and the other 4 for angles > 90 deg. But that was and is a matter of definition. It remains that 80 is not 100, sorry.
And so what? No one is claiming that 80° = 100°, but the sine of 80° = the sine of 100°. Similarly sin(30°) = sin(390°), even though 30° and 390° are different angles.
Getting away from trig functions, do you have a problem with someone saying that ##(-2)^2 = (2)^2 = 4##, even though ##-2 \ne +2##? It's really the same idea -- the squaring function and all of the trig functions are not one-to-one, so different inputs can have the same output.
Hey, I know the rules, have for some 60 years - I'm challenging the rationale, not the rules. I do know they work! The only rationale I know is that they work.
Philosophically speaking, the sine of 100 is a noumenon; the sine of 80 is a phenomenon. There is no such thing as "opposite over hypotenuse" for 100 deg. Saying it's the same as "opposite over hypotenuse" for 80 deg. is a copout that happens to work in our algebraic construct, which is it sole raison d'etre.
That's a pretty strong rationale!
In addition, the real definitions of the cosine and sine of an angle are as mentioned -- the x and y coordinates on the unit circle.
The thing is, in any context more advanced than high school trig, the sine isn't defined as "opposite over hypotenuse." I don't see why sin(100°) is any less a phenomenon than sin(80°) (I had to look up noumenon). If you understand the trig functions in terms of the unit circle, the evidence that the sines of these two angles are equal is easily discernible.
admittedly so!
Thing is, in high school they told us what sin(100) meant & didn't provide any further rationale, best I remember.
Which maybe is not all that much after nearly 60 years.
