What does erf(t) mean in the integral of e^(-t^2)?
8 replies · 2K views
karush
MHB
https://www.physicsforums.com/attachments/9527
ok from online computer I got this
$\displaystyle\int_0^x e^{-t^2}=\frac{\sqrt{\pi }}{2}\text{erf}\left(t\right)+C$
not sure what erf(t) means
$$\mathrm{erf(z)}$$ is so called error function.
But you shouldn't need to know that to be able to solve the problem.
ok but isn't this just going to be $y=\dfrac{\pi}{2}$ which is just a horizontal line
the integral function defining $g’$ is not a constant
the graph of $e^{-t^2}$ is a bell shaped curve, symmetrical to the y-axis and always positive.
for $0<x<2$, $g’ > 0$ (why?)
also, $g’’ > 0$ (why again?)
... what does that say about the behavior of $g$?
Karush, you are making this much harder than it should be!
You are given that [tex]y'= \int_0^x e^{-t^2}dt[/tex].
Since [tex]e^x[/tex] is positive for all x certainly both [tex]e^{-t^2}[/tex] and [tex]\int_0^x e^{-t^2}dt[/tex] are positive for all x and t. The derivative and second derivative of y are positive for all x. That is all you need.
$g’’ = e^{-x^2} > 0$ for all $x$
$g’ > 0$ for $x > 0$, $g’=0$ at $x=0$
$g’ < 0$ for $x < 0$
skeeter said:
$g’’ = e^{-x^2} > 0$ for all $x$$g’ > 0$ for $x > 0$, $g’=0$ at $x=0$
Let g be a function with first derivative given by
$$\displaystyle g'=\int_0^x e^{-t^2}\, dt$$
Which of the following must be true on the interval $0<x<2$
a. g is increasing, and the graph of g is concave up.
b. g is increasing, and the graph of g is concave down.
c. g is decreasing, and the graph of g is concave up.
d. g is decreasing, and the graph of g is concave
e. g is decreasing, and the graph of g has a point of inflection on $0<x<2$
ok not sure which of options fit (e) looks plausible
You are not sure? Haven't you read the responses here?
You are given that $g'(x)= \int_0^x e^{-t^2}dt$ and you have been told that this integral is positive for all x. (Because the integrand is positive for all t.) If a function has positive derivative is it increasing or decreasing?
By the "fundamental theorem of Calculus" [tex]g''= e^{-t^2}[/tex] which is always positive. If a function has positive second derivative is it convex upward or downward?
g is bell shaped so it convex down
