What does looping over a matrix in Matlab actually do?
  • Topic: MATLAB
  • Thread starter Thread starter gfd43tg
    Matlab Matrix
10 replies · 5K views · last reply
gfd43tg
Hello, this block of code was given on a previous exam
Code:
M = [1 3 -2; 7 -5 1];
temp = 0;
for k = M
    temp = temp + k(2)
end
temp
And we are supposed to give the final output of temp. I have no idea how one loops over a matrix, not even elements or anything. What the heck does k = M mean?
So I just do temp = 0+7 on the first iteration, but what happens on the next iteration? temp = 7 + 7?? I ran this code and got 3. Does the value of k(2) change or something?
Read the documentation! http://www.mathworks.co.uk/help/matlab/ref/for.html
Or if you prefer learning by doing, try something like
Code:
for k = M
   disp('Start iteration, k =')
   disp(k)
end
Okay, well I did a new example
Code:
 B = [1 2; 3 4];
EDU>> temp = 0;
EDU>> for k = B
for j = B
k
j
temp = temp + k'*j;
end
end
k =
     3j =
     3k =
     3j =
     4k =
     4j =
     3k =
     4j =
EDU>> temp
temp =
    58
I see how the 2nd one iterated it's k's. It just went through columns of k. Why is it here that it goes through all the columns twice? I don't see the connection. My initial thought was that it would be [itex]\begin{pmatrix}1 & 3 \end{pmatrix} * \begin{pmatrix} 1 \\ 3 \end{pmatrix} = 10[/itex] on the first iteration, then [itex]\begin{pmatrix}2 & 4 \end{pmatrix} * \begin{pmatrix} 2 \\ 4 \end{pmatrix} = 20[/itex], hence the answer would be 30. Why is the code not changing k on the 2nd iteration? It is still ##\begin{pmatrix} 1 & 3 \end{pmatrix}##.
The documentation says
creates a column vector index from subsequent columns of array valArray on each iteration. For example, on the first iteration, index = valArray(:,1). The loop executes for a maximum of n times, where n is the number of columns of valArray, given by numel(valArray, 1, :). The input valArray can be of any MATLAB data type, including a string, cell array, or struct.
So it should be at the 2nd column for the 2nd iteration of k, yet it is still on the first.
It was an old test problem, I am trying to prepare for the final exam.
You have a history of beef with my old test problems. It seems to me that the prof writes cryptic or confusing exam problems, I wouldn't be a bit surprised if it's on purpose
When you have multiple loops, the inner loop(s) must complete before the outer loop advances.
In other words, each iteration of the outer loop runs against every single iteration of the inner loop.
For example,
Code:
for k=1:2
    for j = 1:10
        %stuff in loop
    end
end
In this example, k=1 first. Then the inner loop goes over every single value of j (from 1 to 10), while k is still 1. Once the inner loop finishes, the outer loop advances to k=2 and the inner loop runs a second time.
This means that when you have 2 (or more) loops, the total number of iterations is equal to the number of possible values in each loop, in this case (# values in outer loop) * (# values in inner loop). In the above example there are 20 iterations, with k = 1 for the first 10 and k=2 for the last 10, and with j varying between 1 to 10 twice.
Connecting this back to your example, you are running two for loops with 2x2 matrices. This means there are 4 iterations, with each value of k in the outer loop running against each possible value of j in the inner loop. It seems like you thought there would only be 2 iterations, so hopefully this explains why there are 4.
You mean all this time with a nested loops the indices are not changing simultaneously? Oh my..
Hey Kreil, I ran into an interesting problem related to what you were saying. So that's nice if you have a definite number for the indices of the loop, but suppose I had a code
Code:
for i = 1:40
for j = i:40
Then how many iterations should I expect? The inner loop has dependency on the outer loop. I'm not sure how much I should multiply by? The outer loop is 40, but the inner loop is what? 40*? = number of iterations
Why don't you write out by hand a few loops, starting with i = 1, figure out how many loops are done using the j counter, and increment i by one? Or, you can program a nested loop with a counting variable. Compare the two results.
I did that and got 820. I was expecting 1600. I am looking at it now more closely with only 5 instead of 40, but it is complicated to put it as a math formula, because once i changes to 2, j only goes from 2:5. I probably would need an equation that would more easily determine it.
Edit: Well, I discovered the answer would be 40 + 39 + 38 + ...
I had to look up that the ##\sum\limits_{k=1}^n k = \frac{n(n+1)}{2}, ##, man I would have had to just add all the numbers in my calculator. Who knows, I might not have seen the pattern either on the real exam.
Didn't you learn about arithmetic and geometric series in high school math?
If not, you will be in for a tough time analyzing the performance of algorithms, etc.
