What does the Fortran 77 command 'write' do and how is it used?
  • Topic: Fortran
  • Thread starter Thread starter Triscas
    Fortran
4 replies · 3K views · last reply
Triscas
Hello,
I'm new using fortran and I don't know what does it mean:
write (4,*) ' '
write (4,310)
write (4,311)
this lines go consecutive in the programm I have to understand.
- might say that 4 is not a reference to a line of the code.
- 310,311 are references about how the format should be
i.e:
310 format('Distance C Elec C Sol Surf Liq Pot Solid Pot ',
&'Liq Cur j main j side 1 j side 2 j side 3')
311 format('(microns) (mol/m3) x or y (V) (V) ',
1' (A/m2) (A/m2) (A/m2) (A/m2) (A/m2)')
I hope someone can help. Thanks
Triscas said:
Hello,
write (4,*) ' '
write (4,310)
write (4,311)
i.e:
All of your write statements send output to unit 4, the first number in the parentheses.
write (4,*) ' ' -- prints a single space (' ') on unit 4, using a default format.
write (4,310) -- prints the string in the format statement in line 310, on unit 4. This string appears to be a header of some sort.
write (4,311) -- prints the string in the format statement in line 311, on unit 4. This string also appears to be some sort of header.
what does unit 4 mean? The values will have a length of 4 characters?
yes, i also understood they're a header the other outputs. The second might be the units of the first
The unit number indicates which device you want to write to. In this case it would probably be a disk file that was assigned a unit number with an OPEN statement.
Thanks for the answer, Mark.
