What does the g-factor, from say ESR, tell you?
  • Context: Graduate
  • Thread starter Thread starter maverick_starstrider
    Esr
The discussion revolves around the significance of the g-factor obtained from Electron Spin Resonance (ESR) data. Participants explore what information can be inferred from the g-factor, its implications in different contexts, and the factors that may cause variations from the expected value of 2.0003.
  • One participant inquires about the implications of a specific g-factor value, asking what it indicates about the system being studied.
  • Another participant references external sources that suggest the g-factor, specifically Δg, serves as a unique identifier for molecules, although this may not apply universally across different contexts.
  • A further contribution distinguishes between trivial cases of g-factor application, such as identifying free radicals, and more complex scenarios in condensed matter physics where ESR is used to extract deeper insights about the material.
  • One participant mentions the role of peak splitting in identifying hyperfine interactions, but seeks clarification on the specific insights provided by the g-factor itself.
  • A later post indicates that a document was found that discusses the topic in greater detail, suggesting further exploration of the g-factor's implications.
Participants express varying levels of understanding and application of the g-factor, with some focusing on its identification role and others on its implications in more complex systems. The discussion does not reach a consensus on the specific insights provided by the g-factor.
There are limitations in the discussion regarding the assumptions made about the g-factor's role in different contexts, as well as the dependence on specific definitions and interpretations of the g-factor in ESR studies.
From ESR data you can extract the g-factor and "effective" magnetic field. Let's say I get this g-factor from ESR, what does it tell me? i.e. "if the g-factor is X then Y is happening in the system". What specific information can I get from knowing this factor? What causes it to differ from 2.0003.. whatever?
atyy said:
I googled and found http://chemwiki.ucdavis.edu/Physical_Chemistry/Spectroscopy/Magnetic_Resonance_Spectroscopies/Electron_Paramagnetic_Resonance/EPR:_Interpretation.
"The magnetic field for resonance is not a unique “fingerprint” for the identification of a compound because spectra can be acquired at different microwave frequencies. Then what is the fingerprint of a molecule? It is Δg."
Right but this is the trivial case. Like when biologists use it to identify free radicals in solution. I'm talking about thing like in Condensed Matter, where you already know what the substance is but people do ESR to tell you... something. I understand that the splitting of peaks can help you identify hyperfine splitting and thus the relative influence of nearby ionics cores on the free electron but what does the g-factor tell you?
  • · Replies 19 ·
  • · Replies 0 ·
  • · Replies 16 ·
