What does the notation f|A mean?
In summary, the conversation discusses the notation f|A in the context of a function f, with A and B being sets. It is typically written as a subscript and indicates that the domain of f is restricted to only A. This notation is used in the statement to signify that F is restricted to the intersection of U_0 and U_{-\lambda}, which is consistent with its usage in other instances in the text.
pellman
684
Here is an instance of the notation in context.
If [tex]U_\lambda = F_\lambda(U_0)[/tex] and [tex]U_\lambda\cap U_0\neq\emptyset[/tex], then [tex]F_\lambda |U_{-\lambda}\cap U_0 :U_{-\lambda}\cap U_0 \rightarrow U_0 \cap U_\lambda [/tex] is a diffeomorphism and its inverse is [tex]F_{-\lambda}|U_0 \cap U_\lambda[/tex].
So what does the notation [tex]f|A[/tex] in [tex]f|A:A\rightarrow B[/tex] (where f is a function and A and B are sets) mean?
Mathematics news on Phys.org
It's usually written f|A as a subscript; it means f with its domain restricted to only A. While you don't have the original definition up, obviously the original domain of F in your statement was U0 (or some superset thereof) and now they're looking at F restricted to the intersection with U-lambda
That fits the other instances of its usage in the text. Thank you.
1. What is the meaning of the notation f|A?
The notation f|A refers to a function f that is restricted to a subset A of its domain. This means that the input values of f are limited to the elements in set A.
2. How is the notation f|A different from just f?
The notation f|A specifies that the function f is only defined for the elements in set A, while the notation f does not have any restrictions on its domain.
3. Can the notation f|A be used for any type of function?
Yes, the notation f|A can be used for any type of function, including continuous, discrete, and multivariate functions.
4. What does the vertical bar | symbol in the notation f|A represent?
The vertical bar | symbol in the notation f|A represents the restriction of the function f to the subset A of its domain.
5. Can the notation f|A be used for infinite sets?
Yes, the notation f|A can be used for infinite sets, as long as the function f is defined for all elements in the subset A.
  • Differential Equations
  • General Math
  • Linear and Abstract Algebra
  • Quantum Physics
