What happens after the air is evacuated?
  • Thread starter Thread starter Raven1972
    Air
When air is evacuated from an airtight glass container containing water, the water begins to boil due to the reduction in air pressure, which allows water molecules to transition into vapor. This process occurs without an external heat source, leading to a decrease in the temperature of the remaining water as it loses energy through vaporization. The discussion confirms that the correct outcome is option B: the water starts boiling and the temperature decreases.
  • Understanding of phase changes in liquids
  • Basic knowledge of vapor pressure and boiling points
  • Familiarity with thermodynamics principles
  • Experience with experimental setups involving vacuum conditions
  • Research the relationship between vapor pressure and boiling point in liquids
  • Explore the principles of thermodynamics related to phase changes
  • Investigate the effects of reduced pressure on boiling and freezing points
  • Learn about experimental methods for creating vacuum conditions in laboratory settings
Students in physics or chemistry, educators teaching thermodynamics, and anyone interested in the behavior of liquids under varying pressure conditions.
Raven1972
1. An airtight glass container contains a bowl of water. The temperature of the water is measured. If the air is extracted out of the container what happens to the water?
2.
A) The water starts boiling and the temperature increases
B) The water starts boiling and the temperature decreases
C) The water freezes and the temperature increases
D) The water freezes and the temperature decreases
3. To my mind the water would start boiling due to the reduced air pressure enabling free movement of the water molecules to become vapour. But this loss of steam from the liquid should mean that the remaining water gets colder due to its effective loss of energy since ther is no mention of an external heat source
Any perspective on my conclusions would be greatly welcomed
Thanks very much! That was exactly what I was looking for :smile:
