What Happens to the Water Produced During Fuel Combustion?
The discussion revolves around the implications of water produced during the combustion of fuels, particularly in the context of calorimetry experiments. Participants explore how the state of water (liquid vs. vapor) affects the heating values of fuels and the overall results of combustion experiments.
  • One participant expresses confusion about the fate of water produced during combustion and its potential impact on calorimetry results.
  • Another participant suggests that gaseous water should not significantly affect calorimeter results, as it behaves similarly to other gases.
  • A later reply indicates that the heat of combustion data typically accounts for the effects of water in combustion products.
  • One participant mentions that the state of water (liquid vs. vapor) is crucial for determining the heating value of a fuel, distinguishing between high heating value (HHV) and low heating value (LHV).
  • There is a discussion about the energy associated with the phase change of water, specifically that liquid water releases more energy upon condensation compared to water in vapor form.
  • Participants share calculations and findings from their experiments, noting that the amount of water produced had minimal impact on their results.
Participants generally agree that the state of water produced during combustion is important for understanding heating values, but there are differing views on the extent of its impact on calorimetry results. The discussion remains unresolved regarding the precise implications of water's state on energy calculations.
Some participants reference the need for more detailed thermodynamic information, indicating that existing resources may not fully address their questions. There is also mention of varying assumptions about the conditions under which the experiments were conducted.
Papak
Hi again,
I was doing some experiments on heat of combustion of various fuels and determine which fuel is better by creating a calorimeter. And its simple and straight forward but i started thinking what happens to the water created by burning the fuel, as an example i was doing methanol and from the formula i get 1.05grams of water for the period of time i ran the experiment and from the amount of fuel burnt. I was thinking where is it created, where does it go what temperature will it be and how will this affect my results. I've been thinking about this for some while and am kinda confused and interested about this, it is irrelevant to my experiment but still i want to know more about it. I checked hundreds of websites and they all don't say much about what i want and my textbooks are like prehistoric and really really vague, Hoping someone can shed some light on my question. Thanks in advance
Regards Papak
Chemistry news on Phys.org
My gut tells me it's probably not a big deal since gaseous water is nothing special. Gaseous water does not have high surface tension, it does not have high heat capacity, and it's not extraordinarily light or heavy. Basically it's no different from CO2, O2, or N2 when it's a gas, so it shouldn't have any affect on your calorimeter results.
I also think most heat of combustion numbers factor in any effects of water, so seeing something like X amount of energy for gasoline and 1.3X amount for diesel is a representation of usable energy you get from burning them.
thank you very much, i also did a few extra calculation including this extra water and it really does nothing to my final results (i used a very wide range of varibles for temperature) so thanks again for the help.
Regards Papak
Nothing about this thread makes a lot of sense.
See the wiki entry for heat of combustion and calorimeter for basic information, as well as other common thermodynamic quantities. Water does frequently have anamolous properties, because of hydrogen bonding. For example, the wiki has some values for surface tension (gases don't have surface tension). Water has a much higher value compared with nonane, methanol, heptane, and ether, for example. Water has a heat of vaporization (near 1 atm.) similar to that of methanol ( ca. 41 vs. 37 kJ/mol, respectively), but higher than non-hydrogen bonded liquids such as propane ( 15.7) and butane (21.0). Whether this is significant or not can depend upon the molecular formula of the fuel and the final p,T of the calorimeter. Finally, remember that heat liberated isn't useful work to, for example, drive an internal combustion engine; expansion of gases provides that.
-Jim
The heat of combustion data for fuels is tabulated and the effect of water in the combustion products can be on the order of about 15% depending on whether the water is condensed out or left as a vapor. Any half decent thermodynamics textbook will have a couple of chapters on this and tables of the chemical energies involved.
Hehehe well neither did it make much sense in my mind but neway. I checked wikipedia and all and it really didnt help much with what i was looking at because I am only doing High shool Chemisty, i know how an internal combustion engine runs but i wast looking at fuels only for running cars or engines but looked at the best fuel in relation to the energy released during combustion in joules. What i was wondering and what i asked was whether the water created in combustion would alter the actual value of these fuels by taking in some amount of energy or somehow other alter my final results. But as ShawnD said it was more likely pointless as it was very slight. I only got a full 1.05g of water produced and changed a lot of varibles such as the Specific heat capacity, the inital temp and final and the amount of heat it could absorb was minimum. And thank you russ_watters ill borrow a thermodynamic book next time I am at the library and read more into it, its seems quite interesting. Regards papak
The product water state is very important in determining the heating value of a fuel. If the water created is liquid, you have the high heating value or HHV. If it is vapor, you have low heating value - LHV. The difference between HHV and LHV is the vaporazation of water at 100 degrees C which is 2.3kJ/gram
Im unsure what you are saying pixel. does that mean that for every gram of liquid water created, 2.3kj's of energy given off from the combustion reaction will be taken in by the water, making my actual answer 2.3kj*amount of water in g, less than what it should be or is it the opposite. Regards Papak
No, contrarily, for every gram of liquid water created, you have 2.3kj more compared to the case that amount of water is still in the gas phase. Remember, the vapor water gives off heat when it condenses.
Ah okay well that's much better because I've only had condensed water on one of the experiments thank you for clarifying this and now that you put it that way its very logic and i feel foolish for not realizing it myself straight away hehe. Thanks to every1 for helping
It is nice to hear that. I think that is the way we help each other in the forum.
Hehe i guess and thank you to all again, its lead to some interesting reading.
9K
  • · Replies 16 ·
