What if inertial mass did NOT = grav. mass?
In summary: Mass is a measure of resistance to change in motion. Gravitational mass and inertial mass need not be equal, just proportional. If they are not proportional then the rate at which an object falls will depend on the inertial and gavitational mass. The equivalence principle woulf then no longer hold to be true.
smithpa9
40
What if inertial mass did NOT equal gravitational mass?
How would our normal daily existence be different?
Most interesting and creative answer wins !
[Edit: This is intended to be a fun question to answer, but I'm hoping to learn something quite serious from it. The force of attraction between two charged particles is a function of their charge and distance apart. The resistance to that force is the inertial mass of the particles, which has little to do with the charge. The stronger the charges (assuming oppositely charged) and the shorter the distance, the greater the acceleration. The greater the inertial mass, the less the acceleration. Similarly with magnetic bodies. The acceleration due to magnetic attraction is resisted by the inertial mass, having little to do with magntism.
Not so for accleration due to gravity, where the attraction and resistance are both due to mass (given the equivalence of gravitational and inertial mass).
If they weren't equivalent, how would the simple act of walking, or throwing a baseball or driving a car, or flying a rocket to the moon, be different?]
Eotvos would be coming to haunt you (being Transylvanian, he was related to Dracula)
Let's put aside charge for a moment, and relativistic speeds. Mass is a measure of resistance to change in motion.
When we talk about inertial mass, we're usually looking at a stationary mass and thinking about applying a force to get it moving. So we give it a push, and we measure the force applied and the time we applied it for, whereupon we see our object accelerating by a measured amount. We then calculate the inertial mass as a relation between the force, time and acceleration.
When we talk about gravitational mass, the force acting on our object is gravity instead of pushing. It's a different type of force, but it's the same object. How can that object exhibit a different resistance to change in motion to one flavour of force compared with another? It can't. Force is force.
OK, the magnitude of the force might vary with the distance from another mass, then catching a ball might come with a late rush and a click, like you were catching a magnet with a magnet. And then it would be real hard to throw the ball away. But that's a whole different kettle of fish from what you were asking. And I can't see how what you were asking makes sense. Even on the moon.
Pete
Heavier objects would fall faster than lighter objects.
Now that's got me thinking. Does anybody know the answer to this:
If we held two earth-sized planets ten miles apart and then let go, would their surfaces accelerate towards one another at 9.8ms-2 ?
10 miles is barely any distance. But assuming an ideal situation, yes, they will have the same accelaration. Gm/r^2 will be same in both cases. It's symmetrical...you can't expect one to move faster than the other.
I was wondering if they'd accelerate towards one another at a combined closing of rate of 19.6ms-2.
The gravitational forces cancel, so of course there would be no acceleration towards each other or in any other direction, at least for the surfaces that are 10 miles apart.
By the way, holding the planets apart might be kind of tough on your wrists.
Carl
Farsight - I think Neutrino is right. Unless they were in mutual orbit, the gravitational acceleration between two Earth-sized planets positioned only 10 miles apart should be approx. 9.8 m/s^2 in total. Both would move towards the center of mass of the two (halfway in between) at about 4.9 m/s^2.
Reasoning: 9.8 m/s^2 is roughly the gravitation acceleration at the surface of the Earth for ANY OBJECT, regardless of its mass. 10 miles, compared to the 4,000+ miles radius of the Earth is not significantly different, so 9.8 is probably still correct to one decimal.
An apple, or an Elephant, or the Moon, or another planet Earth, all if positioned just 10 miles above the Earth, would fall at the same speed (ignoring air resistance). And they all would fall toward their common center of gravity. But with the apple and the Elephant, that center is essentially the center of the Earth since it's so much more massive. And the apple and elephant do most of the accelerating and the Earth barely budges.
But in your example of two Earths, they would both share the acceleration equally because of their identical masses.
pym_phy and actionintegral - very insightful responses !
So, if A) gravitational mass was greater than inertial mass, then Aristotle would have been right all along. . . heavier objects would fall faster than lighter ones.
But if B) inertial mass was greater than gravitational mass, then LIGHER objects would fall faster than HEAVIER objects ! Wouldn't that be weird !
Objects falling from great heights might break apart on their fall as the heavier/denser parts separated from the lighter/less dense parts because of the differential in gravitational forces and inertial forces. ??
Would carrying a 15 lb. bowling ball in one hand and an 8lb. one in the other would feel quite strange, as perhaps the 8lb. ball would be easier to keep from dropping, but would offer more resistance to the change of direction the forward and back motion of your arms as you walked?
Sounds ripe for an Isaac Asimov novel !
Eotvos has demonstrated long ago the equivalence between the "two" masses. Reenactments of the Eotvos experiment have brought the error bars of the experiment towards 10^-20 (see the Eot-Wash experiment). So, if you continue to post, Eotvos' vampire will come hunting and haunting
And he'll get you!
Clj4. . . I think you may have misinterpreted the intent behind my question. :-) I have no quarrels with Eotvos, and certainly am not trying to deny that inertial and gravitational mass are equal. Of course they are equal.
I just thought it was in interesting question to contemplate what it would be like if we had been born into a universe where they were somehow not equal.
Plus, sometimes it helps me understand things better if I can contemplate what it would be like if the laws of nature were reversed somehow.
But I'll offer my offical appologies to Eotvos if in case I've offended him (or you).
Yes, I understood. I thought it was a contest for the funniest answers.
:blushing:
Oh yeah. . . . in that case, you clearly win !
No. The 9.8ms-2 refers to test particles falling in the gravitational field of Earth assuming that the motion of the Earth can be neglected. Thus a coffee cup would fall at 9.8ms-2 but Jupiter wouldn't. In fact Jupiter's mass is so much larger than Earth's that Earth would fall in Jupiter's gravitational field as if Jupiter was at rest. Then the Earth would fall at a different acceleration. The rate a body falls depends on where the body is. A body such as the Earth would not fall as if the entire mass was located at its center unless the field was uniform enough so that spacetime curvature could be ignored.
Pete
pmb, or anybody: Supposing I dropped a test particle into a black hole and timed its initial fall, then calculated its acceleration at 9.8ms-2. Now if I repeat this test replacing the test particle with a black hole identical to the other one, would the two black holes accelerate towards one another at 9.8ms-2?
No.
Pete
There is a project under way at CERN to produce and study neutral anti-hydrogen. A key experiment in this project is the comparison of the gravitational infall rates of neutral antihydrogen and hydrogen. This is a critical test of the weak equivalence principal. Not a funny answer, but the most relevant I could come up with.
http://alpha.web.cern.ch/alpha/overview.html
If inertial mass is not equal gravitational mass, general relativity changes in general objectivity. Therefore uniformly accelerated elevator is not equal to homogeneous gravitational field.
Indeed. In fact, we would make them equal, by redefining Newton's gravitational constant, G.
What needs to be, is that the ratio of inertial mass to gravitational mass is the same, for all bodies.
Well, assuming that we can replace a spherical mass by a point mass (there's a theorem on that, but I'm not sure it applies in exactly this circumstance), we have two point masses of the mass of the Earth at a distance of 2 R (plus 10 miles).
Now, we know that the gravitational attraction of earth1 on earth2 is G M^2 / (2 R)^2, so filling this in into Newton's second law in the inertial frame which is the center-of-mass frame:
M.g1 = G M^2 / (2R)^2 or g1 = G M / 4 R^2
g1 is the acceleration with which earth2 is accelerating towards earth1.
Now, for a test particle at the surface of the earth, we have:
m g = G m M/R^2 or g = G M/R^2 = 9.81 m/s^2, so we find that g1 = g/4
By symmetry, g2, the acceleration by which earth1 is accelerating towards earth2, is also equal to g/4.
So we have that both Earth's accelerate towards the center of gravity with an acceleration of g/4 ; so from the PoV of the surface of one, the other is accelerating 2 g/4 = g/2.
So, as seen from the surface of earth1, earth2 is "falling" with an acceleration of g/2 = 4.9 m/s^2.
Under the assumption that we can use the theorem that a spherical mass can be replaced by its mass concentrated in its center, of which I'm not 100% sure that I can apply it here...
If you start with R>> than the radius of earth1 , earth2 then your calculation would work perfectly because the volume integrals can be shown to be independent (almost) of the Earth radius.
There is a problem, though: we all know that the test probe will experience a given acceleration (say 9.81m/s^2) only in the vicinity of the Earth surface. So , now you need R to be very close to the Earth radius. Thus, your proof contains a contradiction.
So , we cannot solve this problem simplistically. What to do?
Here is the calculations leading to the correct solution (within Newtonian physics)
http://scienceworld.wolfram.com/physics/SphericalShellGravitationalPotential.html
Yes, well, what does it say ? For a full sphere, outside of the sphere ?
(so R > b, and a = 0)
We have that the potential is - 4 pi/3 b^3 rho G / R
Now, 4 pi / 3 b^3 rho is nothing else but the total mass of the sphere, so we have that outside of the sphere, at a distance R from its center, the potential is - M G / R which is exactly the same as if we lumped the entire mass at its center. That's the theorem I talked about.
What I'm slightly less sure of, is: does a sphere with density rho, bathing in such a potential, also act as if it were a point particle with its mass in its center ?
That is, if we sum all the forces acting on all the parts of a sphere, exposed to the potential of a point particle (but of course off-center), does this sum equal the force that would act on a point particle in the center of that sphere ? It is somehow the reciproke of the above theorem and my gut feeling would tell me that it is ok, but I should work it out.
This was what I'm not sure about.
There was a more severe problem, I am not sure you caught what i was saying.:
You are using R in two contradictory ways:
1. To calculate the attraction between the two "Earth's" (R is big, much bigger than the "earth" radius)
2. to calculate the acceleration of the test probe (R needs to be very close to the "earth" radius in order to get your predicted value of 9.81m/s62).
You cannot have both 1 and 2 to be true.
clj4 said:
There was a more sever problem, Iam not sure you caught what i was saying.:
2. to calculate the acceleration of the test probe (R ineeds to be very close to the "earth" radius in order to get your predicted value of 9.81m/s62).
Eh, what do you mean ? R is Earth's radius. So the two centers of the two Earth's are at a distance of 2 R (+ 10 miles), because the surfaces are touching each other almost.
The point is that the theorem allows us to replace the gravitational effect of a full sphere by the gravitational effect of all its mass in a point in its center, as long as we stay outside of the sphere of course.
So I replaced the two Earth's by their respective equivalent point masses in their centers which are now at a distance of 2R (+ 10 miles, which I neglect).
For the "active" part, I know the theorem is true (and you provided an explicit reference for it). For the passive part, I'm simply too lazy to work it out, I'm pretty convinced that it is in fact the same calculation, but there's some uncertainty left.
The point is that the "earth as a point mass" is not an approximation, it is exact, even for the gravitational effect 5 cm above its surface. So I do not need to be far away from Earth for it to work.
Then you have not calculated the attraction force correctly (look at your formula, you are using only 2R, there should be 2R+10). The bigger problem is that the formula holds only for distances between bodies that are MUCH LARGER than the bodies' radius.
You simply cannot use the "lazy" way. I think Pete said the same thing a few posts earlier. See post #16.
That's a tiny correction, vanesch threw it out for simplicity.
It assumes point masses, but due to a geometric theorem originally discovered by Newton it also holds for spheres and spherically-symmetric balls.
Rach3 said:
That's a tiny correction, vanesch threw it out for simplicity.It assumes point masses, but due to a geometric theorem originally discovered by Newton it also holds for spheres and spherically-symmetric balls.
I really think that you need to recheck your calculations. The approximation applies when the distance between the centers of the spheres is MUCH BIGGER than the spheres' radiuses. This is not the case in the example and creates a "paradox". Someties "lazy" solutions are not the best thing, they waste more time in argument than applying the correct (albeit more complicated) math.
It would be true for the attraction of a sphere to a point mass, by exactly the symmetry you are thinking of (just invoke Newton's 3rd); the sphere, attracted to a point mass, behaves as a point mass. Then by superposition, it would be true for the attraction of a sphere to two point masses as well - since you can just add the forces. So there you can just integrate over a whole bunch of points - and it is clear that a uniform sphere behaves as a point mass, in an arbitrary gravitational field (ignoring relativity, inhomogenities, etc.) Thus two ideal spheres attract each other as point masses.
In a real situation of course, tidal effects would rip the planets apart!
  • #31
This was also the kind of reasoning I did in my head...
Sure, and as pointed out somewhere else, holding them, before the experiment, 10 miles apart, might put some load on your wrists too :smile:
As I said before, and as rach3 confirms, it is not an approximation. It is a theorem that gives you the exact field, as long as you have to do with spherical objects. It is indeed a theorem by Newton himself, and actually, I read that he held back the publication of his theory of gravity until he found that theorem (and invented the necessary calculus that goes with it). You quoted the theorem yourself in the reference you gave !
  • #32
Yes, except that Pete forgot that the center of the second Earth is not at distance R, but at distance 2 R (plus 10 miles :smile: ).
  • #33
There's nothing lazy about it - it's an application of Gauss' law and some symmetry arguments. I'm curious as to what "paradox" you have in mind?
  • #34
OK,
I will try for one last time. In your derivation R has two different meanings.
In the first acception R is in effect half the distance between the twi "Earth's" (forget the 10km, let's just assume that the distance between the planets is very big wrt the radius of the planets such that we produce the solution for a realistic case).
In the second acceptance (the case of the probe), R is in effect the radius of one of the "Earth's". So, your solution only works if the two "Earth's" are at a distance [tex]2R+\epsilon[/tex] with [tex]\epsilon[/tex] very small. Sure, you are going to answer, you chose [tex]\epsilon=10km[/tex], which is indeed very small but the solution is far from being general. This is why I do not like it. The OP did not mention anything about the two planets being very close, we should always give general solutions, not particular ones. Does this make sense, now?
  • #35
In a more constructive way, if we start with the rigurous formula of the potential from the wolfram page, we can determine the acceleration as a function of the distance between the planets for ANY value. That is for "earth1" falling towards "earth2" (and viceversa) starting from an ARBITRARY distance z and from an initial speed say, zero. The acceleration will be a variable.
I will not have access to a computer for the next week, I am going away from any math and physics and emails and forums. What I wanted to say, is that we should aspire towards generic solutions.
