What is the Definition and Properties of a Cross Product in Vector Algebra?
The cross product of two vectors, denoted as \(\mathbf{A} \times \mathbf{B}\), results in a pseudovector that is perpendicular to both original vectors. Its magnitude is calculated using the formula \(|\mathbf{A} \times \mathbf{B}| = AB \sin \theta\), where \(A\) and \(B\) are the magnitudes of the vectors and \(\theta\) is the angle between them. The cross product is anti-commutative, meaning \(\mathbf{A} \times \mathbf{B} = -\mathbf{B} \times \mathbf{A}\). Additionally, the cross product can be represented as the determinant of a 3x3 matrix formed by the components of the vectors in a right-handed orthonormal basis.
  • Understanding of vector algebra and operations
  • Familiarity with Cartesian coordinates and components
  • Knowledge of determinants and matrix representation
  • Basic concepts of polar vectors and pseudovectors
  • Study the properties of pseudovectors in physics
  • Learn about the geometric interpretation of the cross product
  • Explore applications of the cross product in physics, particularly in torque and angular momentum
  • Investigate the relationship between the cross product and the wedge product in differential geometry
Students and professionals in physics, mathematics, and engineering who require a solid understanding of vector operations, particularly those involved in mechanics and geometric interpretations of vectors.
Definition/Summary
The cross product of two vectors \mathbf{A} and \mathbf{B} is a third vector (strictly, a pseudovector or axial vector) \mathbf{A}\times\mathbf{B} perpendicular to both of the original vectors, with magnitude equal to the product of their magnitudes times the (positive) sine of the angle between them, and in the direction determined by the right-hand rule.
It is anti-commutative: \mathbf{A}\times\mathbf{B}\,=\,-\,\mathbf{B}\times\mathbf{A}
If the vectors \mathbf{A} and \mathbf{B} are considered as 1-forms, then the wedge product \mathbf{A}\wedge\mathbf{B} is a 2-form (a directed area), and its dual \ast(\mathbf{A}\wedge\mathbf{B}) is a dual 1-form, corresponding to the pseudovector \mathbf{A}\times\mathbf{B}
Equations
The magnitude of \mathbf{A}\times\mathbf{B} is the area of the paralleogram with sides \mathbf{A} and \mathbf{B}:
|\mathbf{A}\times\mathbf{B}| = AB \sin \theta
In terms of Cartesian components:
(\mathbf{A}\times\mathbf{B})_x = A_y B_z - A_z B_y
(\mathbf{A}\times\mathbf{B})_y = A_z B_x - A_x B_z
(\mathbf{A}\times\mathbf{B})_z = A_x B_y - A_y B_x
The triple product (scalar product) \mathbf{A}\cdot(\mathbf{B}\times\mathbf{C}) is the volume of the parallepiped with sides \mathbf{A} \mathbf{B} and \mathbf{C}, and therefore:
\mathbf{A}\cdot(\mathbf{B}\times\mathbf{C})\,=\,\mathbf{B}\cdot(\mathbf{C}\times\mathbf{A})\,=\,\mathbf{C}\cdot(\mathbf{A}\times\mathbf{B})
The repeated cross product \mathbf{A}\times(\mathbf{B}\times\mathbf{C}) is a vector perpendicular to \mathbf{A}, and is a linear combination of \mathbf{B} and \mathbf{C}:
\mathbf{A}\times(\mathbf{B}\times\mathbf{C})\,=\,(\mathbf{A}\cdot\mathbf{C})\mathbf{B}\,-\,(\mathbf{A}\cdot\mathbf{B})\mathbf{C}
Extended explanation
For two vectors \mathbf{a} = \left(a_x,a_y,a_z\right)\;\;\mathbf{b}=\left(b_x,b_y,b_z\right) in \mathbb{R}^3, the cross poduct can be written as the determinant of a 3x3 matrix:
\mathbf{a}\times\mathbf{b} = \left|\begin{array}{ccc}<br /> \mathbf{i} &amp; \mathbf{j} &amp; \mathbf{k} \\<br /> a_x &amp; a_y &amp; a_z \\<br /> b_x &amp; b_y &amp; b_z\end{array}\right|
Where \mathbf{i}, \mathbf{j}, \mathbf{k} is a right-handed orthonormal basis.
Polar vectors and pseudovectors:
A polar (ordinary) vector is reversed under an inversion of the coordinate axes: \mathbf{a}\ \mapsto\ -\mathbf{a}
However, the cross product of two polar vectors is not reversed: \mathbf{a}\ \times\ \mathbf{b}\ \mapsto\ (-\mathbf{a})\ \times\ (-\mathbf{b})\ =\ \mathbf{a}\ \times\ \mathbf{b}
In other words, the cross product of two polar (ordinary) vectors is invariant (the same) under an inversion of the coordinate axes: this is called a pseudovector (axial vector).
Directed area:
A directed area is a flat surface together with a magnitude (its area), and a sign (\pm) indicating a direction of rotation within the surface (alternatively, indicating a preferred normal direction).
A directed area is an elementary 2-form (a wedge product of two 1-forms).
A general 2-form is a sum of directed areas.
Its dual (in three-dimensional space) is a 1-form in the dual space, corresponding to a pseudovector normal to the surface and with magnitude equal to its area.
Triple product 3-form pseudoscalars and directed volume:
The wedge product of three 1-forms is a 3-form.
In three-dimensional space, all 3-forms are multiples of each other, and so a 3-form is essentially a scalar. To be precise, a 3-form is the dual of a 0-form, which is a scalar.
However, under an inversion of the coordinate axes, a 3-form is multiplied by minus-one, and so a 3-form technically is a psuedoscalar.
The triple product \mathbf{a}\cdot(\mathbf{b}\,\times\,\mathbf{c}) of three vectors is the dot product of a vector and a pseudovector, and is the pseudoscalar equal to the wedge product \mathbf{a}\,\wedge\,\mathbf{b}\,\wedge\,\mathbf{c} of the three vectors, in the same order. It is the directed volume of the parallepiped whose sides are those three vectors ("directed" because it includes a sign (\pm) indicating a direction of rotation around the common vertex).
* This entry is from our old Library feature. If you know who wrote it, please let us know so we can attribute a writer. Thanks!
An interesting read is about the geometry of it:
https://arxiv.org/pdf/1205.5935.pdf
and the connections: cross product - Lie algebra - determinant - volume of parallelepiped
I've a doubt regarding the pseudo vector part and I'll be thankful if you could clarify.
Greg Bernhardt said:
Definition/Summary
Equations
Directed area:
In a right hand system suppose I've two vectors i, j then their cross product is ##\mathbf{i}\ \times\ \mathbf{j}\ =\ \mathbf{k}##
When we invert our coordinate system and then try to calculate the cross product of those two vectors we will have ##\mathbf{-i}\ \times\ \mathbf{-j}\ =\ \mathbf{k}##
That means cross product is a polar vector? But that's wrong.
Do we use a left handed system to compute cross product when we invert our coordinate system? Can you please help me, I'm not able to understand it.
Thank you.
Thank you.
You got a definition backwards, it is said that under an inversion (also known as a parity transformation), that ##\vec{x} \rightarrow -\vec{x}## and as you just said, the cross product remains the same. So, it can't be a polar vector (aka "real vector"), so historically they called it a pseudovector, I believe.
  • · Replies 22 ·
  • · Replies 0 ·
