What is a non-orthogonal measurement?
  • Context: Graduate
  • Thread starter Thread starter JK423
    Measurement
A non-orthogonal measurement refers to the projection of a quantum state |Ψ> onto a set of non-orthogonal states {|Ψa>}, as opposed to orthogonal measurements that project onto orthogonal eigenstates. In quantum mechanics, this concept is crucial for understanding measurements that do not yield independent results, as the angle between measurement axes indicates the degree of correlation. The Aharonov-Bohm effect serves as a relevant experimental example illustrating the implications of non-orthogonal measurements. The discussion highlights the confusion surrounding the nature of non-orthogonal states and their relationship to eigenstates.
  • Understanding of quantum mechanics principles
  • Familiarity with the concept of eigenstates and observables
  • Knowledge of projection operators in quantum theory
  • Basic grasp of the Aharonov-Bohm effect
  • Study the mathematical framework of Positive Operator-Valued Measures (POVMs)
  • Explore the implications of non-orthogonal measurements in quantum information theory
  • Investigate the relationship between non-orthogonal states and measurement outcomes
  • Review literature on isotropic measurements in quantum mechanics
Quantum physicists, students of quantum mechanics, and researchers interested in the nuances of measurement theory and quantum state projections.
JK423
As the title sais... Can someone explain to me what is a non-orthogonal measurement?
I searched the web by i can't find any definition
Hi JK423! :wink:
What is the context? :smile:
Do you have a specific experiment in mind?
Orthogonal means perpendicular and uncoupled, like x and y axes in Cartesian space. But you can also use other axes, for example you could obtain x' and y' by rotating everything a few degrees clockwise.
Say you measure the length of the projection along the x-axis of some typical vector v, and record the result. Now, if you were to measure next the y-axis projection of that vector then you would get another result completely independent from your first one, but if instead you had next measured the x' axis projection then you would expect to get a result very closely (though not quite 100%) interrelated with your first one.
Measurements in QM are often mathematically analogous to projecting a vector onto an axis, the angle between axes corresponding with degrees of correlation.
A good experiment right off hand would be the Aharonov-Bohm effect.
Thanks for the answers so far..
I'll explain to you my problem a little bit more analytically.
For example, i know that an orthogonal measurement projects a state |Ψ> onto an eigenstate of the observable we are measuring.
Now I am not sure what a non-orthogonal measurement does...
Of what I've understood (from the notes of Preskill I am studying) when we perform a non orthogonal measurement, |Ψ> is projected onto a state |Ψa> from a set of non-orthogonal state {|Ψa>}. [Like in an orthogonal measurement, |Ψ> is projected onto an (eigen)state from a set of orthogonal states (the rest of eigenstates)]
And there i got a problem. How can the set {|Ψa>} be of non-orthogonal states?
Since we are measuring an observable, then |Ψ> should be projected onto an eigenstate of that observable! So i conclude that |Ψa> is an eigenstate! But how can {|Ψa>} be of non-orthogonal eigenstates?? :rolleyes:
im confused.. :frown:
Hi JK423! :wink:
Does this help … http://en.wikipedia.org/wiki/POVM" ? :smile:
Thanks tiny-tim, but i had looked at it but didnt have the info i needed!
My professor helped me and figured it out..! :)
Guys: Would it be proper to say that 'non-orthogonal' is synonymous with 'isotropic', and in any context?
  • · Replies 19 ·
