What is a Pole of Order n in Complex Analysis?
The discussion revolves around the concept of poles in complex analysis, specifically focusing on the definition and classification of poles of order n. Participants explore the relationship between poles and zeros, questioning the implications of different orders and their significance in the context of complex functions.
  • Participants express confusion regarding the terminology of poles and their orders, comparing them to real-valued functions and questioning the distinction between different orders of poles. There is also a discussion about the classification of zeros and their relation to poles.
The conversation is active, with participants raising questions and providing insights about the significance of pole order in relation to function behavior and complex analysis concepts. Some guidance is offered regarding the evaluation of zeros and their orders, as well as the implications for Laurent expansions.
Participants mention the importance of understanding pole orders for applications such as the residue theorem and Laurent series, while also noting the potential for confusion with concepts like essential singularities and algebraic branch points.
aaaa202
If a complex function has the form:
f(z) = g(z)/(z-a)n then z=a is a pole of order n. I don't really understand all this fancy terminology. Isn't a pole just like when you for a real valued function g(x)/(x-a) don't want to divide by 0 and therefore the function is defined at x=a? If so what is then all this talk about a pole of order n, and how does poles at different orders distinguish from each other? Since you are classifying poles by order, my understanding of a pole as simply a point on which f is not defined is probably wrong or at least lacking something.
Are you familiar with zeros of higher order?
If z=a is a zero of n-th order for a function 1/f(z) , then z=a is a pole of n-th order for a function f(z). Those two are related like that.
Yes okay, but what is the idea of classifying the order of a zero? Surely (z-a)^n is zero for a=z no matter what n. I don't see how n can ever change the properties of the zero?
It tells how "powerful" the zero is.
Technically I'd say that for F(z)=(z-a)^n we have a zero of n-th order z=a because n-th derivative of F(z) at z=a is no longer equal to zero...
This works for all finite arguments.
How would you evaluate what is the order of zero z=0 for the function G(z)=sin(z) ?
You should not look for too much meaningfulness in the definition, but realizing such orders is quite an important thing in complex analysis.
Well, the order of a pole to a function is significant for its Laurent expansion (Taylor series with 1/(z-a)^n terms in it). This is important when you apply the residue theorem (a nice way to calculate integrals you never could do before).
And to elaborate a little on Pzi's post, you can calculate how "much zero" a function f is (or the order of the pole of 1/f) by computing its derivatives at a point. A double root means that you have f=f'=0, triple root f=f'=f''=0 and so on. Some functions have poles of infinite order, such a point to a function is called an essential singularity (like log z in the origin).
log(z) has an algebraic branch point of infinite order at the origin. That's not an essential singularity. The function [itex]e^{1/z}[/itex] has an essential singularity at the origin.
  • · Replies 17 ·
14K
